I picked up an 04 Silverado and it looks like it was not cared for
as well as it should have been.The throttle body has a nice coat
of black film on it and the MAF has the same.The truck is at 50K
now so the question is what are the things to check,change on
this thing?
Any tricks I should know before I try to remove and clean
the TB on the 5.3?
All the fluids:
Coolant
Trans
Oil
Differential(s)
and T-Case if 4x4
Make sure the power steering level and brake fluid level are good, check the spark plugs, air pressure, balance, and alignment, check all the bulbs and brakes. Theses are some of the things I would do if I bought a used vehcile if it was in need.
    1981dustin
    1981dustin
  • Who's Online   3 Members, 0 Anonymous, 1,659 Guests (See full list)
