2002 Z71 Trailer Light Delay
rwaldrop
I have a 2002 Chevy Silverado Z71. I recently puchased a new boat and trailer. When I attach the trailer lights everything comes on okay but there seems to be a 5-7 second delay from the time that I turn on my blinker to when the trailer lights actually start to blink. This is a consistent problem and though they do eventually work the delay makes me a bit nervous on the highway. Especially since I can only assume that the brake lights operate the same way. Any help in this area would be greatly appreciated.
Nobody, huh? Well that figures.
Have you done any troubleshooting to try and figure out what your problem is? Did you test the plug w/o a connector attached to see if you're getting the same delay w/ a multi-meter or a test lamp? What type of plug does your trailer utilize? Have you made any modifications to your truck that might be the culprit? Give us some more info and we'll see what we can come up with but leave the attitude elsewhere.
Another question for you.....is this the factory installed trailer wiring or an aftermarket setup?
what attitude? I meant that it figures that nobody can help me here as that has been the case everywhere else I have turned. You know what? Why don't you go phuc k yourself? How's that for attitude? Phuckin snob. I was asking a simple question. Frankly I don't care enough to have to deal with the likes of you. Thanks for nothin.
Thanks Jackson.....for not tryin to be my father and just offering some advice.
wow dude..........relax. :D:uhoh: he was offering help and your post did kind of come off or should I say it could have been interpreted as attitude. I didn't take it that way but I can see where he was coming from. That doesn't excuse you from telling him to f-off when he was trying to help.
damn
    • These show the problem and symptoms, and I explain things too. to clarify again, I did not change over any computers or wiring (with the exception of the map sensor). All of the computers and wiring are original to the 2010 vehicle   video 1 - background info/explanation and part of the problem   video 2, idle misfire   I think the reason that the MAP sensor is reading High is because the engine is misfiring so there is less vacuum...   Additionally there's a p0102 for the MAF low frequency, and a p0108 for the map high voltage.        Again, apologies for the somewhat long-winded explanation, it's a rather difficult problem to explain without going into the details.
    • You'd want the Pulsar to be safe.  That was the first product that worked for 10 speed trucks that they came out with.   Range Technology 22451 Pulsar LT for 2019-2022 GM Gas Trucks     That said, in the features description of the RA003B, it does list it working with 10 speeds.  However there are reports that the RA003B can cause some drivability issues on early 10 speeds.  So the Pulsar is the safest move IMO.      Range Technology RA003B AFM/DFM Disabler   Features: Range AFM/DFM Disabler keeps you in full power 100% of the time Simply plug into your onboard OBD-II port and it instantly begins working to eliminate the AFM system Disables Auto Start/Stop Blue LEDs The Range AFM/DFM Disabler does not reprogram factory ECU Works in hundreds of applications, 2007-2022, including 10-speed models. Leaves no trace, unplug it to return to factory settings Virtually no battery draw Fits all V6 and V8 General Motors (GM) active or dynamic fuel management vehicles, includes cars, trucks, and SUVs This device does not support the 2022.5+ Refresh model trucks or 2021+ SUVs To confirm your 2022 model truck is compatible with this unit, check your VIN. The 12th digit in an early model must be a '4' or lower Made in USA
    • I have a 2019 new body style high country with a 6.2l L87 and a 10 speed transmission code MQB. Looking for a disabler that is compatible. Most show it’s not. I watched a video on utube from Dons Life that says Ranges RA003B is compatible but when you go to Ranges website and check compatibility it only has a 8L90 trans listed which is an 8 speed.  I don’t want to buy the wrong one. Anyone have any experience with this situation?
    • This actually happened. Be careful where you get your information re: gas price trends.
    • I understand the principle...you don't want to spend $150 for a $0.02 piece of plastic or a little screw and perch thingy.   But this is a problem that looks like it can be reliably solved with a zip tie.   That might hold you over until you can score one at a pick-a-parts yard.
