Tailgate Problems
Volker22
My tailgate won't open becaue the mechanism is broken. I bought a new one and want to install it myself. Any ideas where to start.
Any help would be awesome
thanks
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,410 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
