Farenheit To Celsius
I was wondering were in the hell is the button to change the display of farenheit to celsius on the rearview mirror in a nbs Sierra. It doesn't say anything in the manuel about were it actually is. Thanks.
If you have the Driver Information Center (DIC) and the 4 buttons that control it, cycle through the options on the 3rd button (I think) and see if the English/metric option is there.
Press and hold the on/off button for the mirror for several seconds. I believe that's where you change it from F to C.. and I think that is also how you can temporarily disable the auto-tinting feature...
That changes the DIC not the mirror. I do believe holding the power button works, it did it the last rig I had.
like he said buttons on steering wheel and it will say "Measurements" and then hit the arrow on the bottom left and it will change it then ur done
That only changes the readings on the DIC in the cluster,Not the mirror,You have to push & hold the button on the mirror to change it.
For the 2007+ new body-style Sierras and Silverados with the mirror like the one shown below, do this :
Press and hold the power button on the mirror for about 5 seconds :
The display will start blinking (either "F" or "C" depending on which one it is currently on) :
Press the power button again to change from C to F or from F to C :
Wait a few seconds and it will go back to the temp display :
EDIT : Added clarification that this applies to 2007+ NBS trucks.
i see now sry mis-read exactly what was meant sry guys
No harm. No foul! No problem! :D
The longer I sat here, remembering what I had accidentally found a few weeks ago, the more I questioned what I had done and what those steps had actually accomplished.... hence the pictures. I wanted to go out there and double-check myself. :D
    Daniel422
    Daniel422
  • Who's Online   2 Members, 0 Anonymous, 727 Guests (See full list)
