Hey everyone,
Dustin from realtruck.com again, just letting you know that are sales on covers last month was soo good, they are letting us continue the sale through July!! So if you still need a new top of the line cover I can get you one for 17% off and free standard shipping! Also if we can get a group buy going of 15 or more covers (they dont need to be access covers) I can get you 20% off each of those! And if you buy a access limited cover we are giving away an EZ-Retreiver with that order.
Thanks,
Dustin
  • 4 weeks later...
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
