Where Is Mileage Kept?
I know I have read on here several times people stating it is only kept in the IP however I was reading the new tech news from GM for July this evening and this is what was in it word for word. I even believe I was told I was incorrect for stating this one time after stating this, so now I am more confused than ever ;)
Refer to bulletin 07-08-49-020B for details.
When replacing an Instrument Panel Cluster (IPC), the season odometer value needs to
be programmed into the new IPC. A table in bulletin 07-08-49-020B can be used as a reference guide to help identify what odometer programming method to use. The table lists most 2003-09 passenger cars and trucks (including Saturn), HUMMER H2, and HUMMER H3.
The table in the bulletin lists the component where the season odometer value is stored.
At present, there are three programming methods used:
- the Service Programming System (SPS)
- using the Electronic Service Center (ESC)
- the Tech 2 -- used to program the season odometer value in an exchanged BCM.
An exchanged IPC receives and displays the odometer value from the BCM, over the
serial data circuit, after cycling the ignition or driving the vehicle.
TIP: The updated table is available in the Reference Guide of the TechLink website.
- Thanks to Dan Oden
Heres a copy of the bulletin referenced in the GM-Techlink you mentioned...
xTooltipElement
Service Information
Document ID: 2141327
#07-08-49-020B: IPC Odometer Programming Method Quick Reference Guide - (May 22, 2008)
Subject: IPC Odometer Programming Method Quick Reference Guide
Models: 2003-2009 GM Passenger Cars and Trucks (Including Saturn)
2003-2009 HUMMER H2, H3
2005-2009 Saab 9-7X
Attention: This bulletin applies to vehicles sold in the U.S. and Canada Only.
This bulletin is being revised to add information for the 2009 model year and add new 2009 vehicles. Please discard Corporate Bulletin Number 07-08-49-020A (Section 08 -- Body & Accessories).
The purpose of this bulletin is to provide a reference guide to help identify which season odometer programming method to use after replacing the Instrument Panel Cluster (IPC). The three season odometer programming methods in use today are listed below. In addition, this reference guide lists the component where the season odometer value is stored. The season odometer value may be stored in the IPC, the Driver Information Center (DIC), or the Integrated Body Control Module (IBCM), also commonly called a Body Control Module (BCM).
Season Odometer Programming Methods In Use Today
IPC reprogramming and setup using the Service Programming System (SPS).
Odometer setup at the Electronic Service Center (ESC) when using an exchange IPC/DIC.
Tech2® -- The Tech2 is used to setup a replacement BCM, which includes loading the odometer value that is displayed and stored in the IPC. A replacement IPC will display the previously stored vehicle odometer value, communicated from the BCM, after cycling the ignition or driving the vehicle.
Model
Model Year
Odometer Value Storage
Buick
Century
2003-2005
IPC
ESC
Enclave
2008-2009
IPC
ESC
LaCrosse/Allure
2005-2009
IPC
ESC
Lucerne
2006-2009
IPC
ESC
LeSabre
2003-2005
IPC
ESC
Park Avenue
2003-2005
IPC
ESC
Rainier
2004-2007
IPC
SPS
Regal
2003-2004
IPC
ESC
Rendezvous
2003-2007
IPC
ESC
Terraza
2005-2009
IPC
ESC
Cadillac
CTS
2003-2009
IPC
ESC
DeVille
2003-2005
IPC
ESC
DTS
2006-2009
IPC
ESC
Escalade
2003-2006
IPC
SPS
2007-2008
IPC
ESC
Seville
2003-2004
IPC
ESC
SRX
2004-2009
IPC
ESC
STS
2005-2009
IPC
ESC
XLR
2004-2009
IPC
ESC
Chevrolet
Astro
2003-2005
IPC
ESC
Avalanche
2003-2006
IPC
SPS
2007-2008
IPC
ESC
Aveo
2004-2009
IPC
ESC
Blazer
2003-2005
IPC
ESC
Colorado
2004-2009
IBCM
Tech 2
Cavalier
2003-2005
IBCM
Tech 2
Cobalt
2005-2009
IBCM
Tech 2
Corvette
2003-2009
IPC
ESC
Epica
2004-2006
IPC
ESC
Equinox
2005-2006
IBCM
Tech 2
2007-2009
IPC
ESC
Express
2003-2009
IPC
ESC
HHR
2006-2009
IBCM
Tech 2
Impala
2003-2009
IPC
ESC
Kodiak
2003-2009
IPC
ESC
Malibu
2003
IPC
ESC
Malibu
2004-2009
IBCM
Tech 2
Monte Carlo
2003-2007
IPC
ESC
Optra
2004-2007
IPC
ESC
S-10
2003-2004
IPC
ESC
Silverado Classic
2003-2007
IPC
SPS
Silverado
2007-2009
IPC
ESC
SSR
2003-2006
IPC
ESC
Suburban
2003-2006
IPC
SPS
2007-2009
IPC
ESC
Tahoe
2003-2006
IPC
SPS
2007-2009
IPC
ESC
TrailBlazer
2003-2008
IPC
SPS
Traverse
2009
IPC
ESC
Uplander
2005-2009
IPC
ESC
Venture
2003-2005
IPC
ESC
GMC
Acadia
2007-2009
IPC
ESC
Canyon
2004-2009
IBCM
Tech 2
Envoy
2003-2009
IPC
SPS
Jimmy
2003-2005
IPC
ESC
Safari
2003-2005
IPC
ESC
Savana
2003-2009
IPC
ESC
Sierra Classic
2003-2007
IPC
SPS
Sierra
2007-2009
IPC
ESC
Sonoma
2003-2004
IPC
ESC
TopKick
2003-2009
IPC
ESC
Yukon
2003-2006
IPC
SPS
2007-2009
IPC
ESC
HUMMER
H2
2003-2007
IPC
SPS
2008-2009
IPC
ESC
H3
2006-2009
IBCM
Tech2
Oldsmobile
Alero
2003-2004
IPC
ESC
Bravada
2003-2004
IPC
SPS
Silhouette
2003-2004
IPC
ESC
Pontiac
Aztek
2003-2005
IPC
ESC
Bonneville
2003-2005
IPC
ESC
G5
2007-2009
IBCM
Tech 2
G6
2005-2009
IBCM
Tech 2
G8
2008-2009
IPC
SPS
Grand Am
2003-2005
IPC
ESC
Grand Prix
2003-2008
DIC
ESC
GTO
2004-2006
IPC
ESC
Montana
2003-2005
IPC
ESC
Montana SV6
2005-2009
IPC
ESC
Pursuit
2005-2006
IBCM
Tech 2
Solstice
2006-2009
IBCM
Tech 2
Sunfire
2003-2005
IBCM
Tech 2
Torrent
2006
IBCM
Tech 2
2007-2009
IPC
ESC
Vibe
2003-2009
IPC
ESC
Wave
2005-2009
IPC
ESC
Saab
9-7X
2005-2009
IPC
SPS
Saturn
ASTRA
2008-2009
IPC
SPS
AURA
2007-2009
IBCM
Tech 2
ION
2003-2007
IBCM
Tech 2
L-Series
2003-2005
IBCM
Tech 2
OUTLOOK
2007-2009
IPC
ESC
RELAY
2005-2007
IPC
ESC
SKY
2007-2009
IBCM
Tech 2
VUE
2003-2007
IBCM
Tech 2
2008-2009
IPC
SPS
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
Basically it depends on the vehicle as to where the mileage is stored.
On the Full Size trucks,Both GMT800/GMT900 it is stored in the instrument panel cluster (IPC)
On the Colorado/Canyon's it is stored in the BCM.
Holy Cow Rich! You owe me a new scroll wheel on me mouse!
Sorry Jim,Thats just the way it copied over :lol:
Hopefully everyone can understand it,If not just post what kind of vehicle you want to know about and I'll tell you where the mileage is stored and how its programmed in.
    Zinister101
    Zinister101
  • Who's Online   5 Members, 1 Anonymous, 536 Guests (See full list)
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
