1998 5.7 Vortec Fuel Problem?
Hello all, I'm a newbie to this forum. I see lots of great info posted here and hope that someone can help me with an issue.
Last night I found what appears to be a great deal on a loaded 1998 Silverado Extended cab Z71. The truck shows 148k on the odometer and is extra clean. The problem is that it starts just great but dies after only 3-4 seconds. The engine sounds great when it's running and runs smoothly. When it dies out, the exhaust smells like it's running lean (hot and acrid smell). The engine will start again immediately after it dies and repeats the process. The dealer says this is a fuel pump or clogged fuel filter issue and they are going to fix it. I'm suspicious of a fuel filter being the cause due to the fact that it will start right up again.
I haven't had a chance to drive the truck to check it out any further and wanted to get some input from learned people on what to check for with the engine etc. I tentatively have this truck bought for $4300. If it passes all the other tests, it should be a steal.
Thanks for any input into this issue!
i would agree with it being either ff or pump, ff is easy to change and inexpensive, try that first, and if you can check your fuel pressure, should be 55-60psi
thanks for the reply!
I also read somewhere this morning that another owner of a 1998 Z71 had let his truck sit for some time and the battery went dead. He said he jumped it to start it and had these same exact symptoms. He went on to say that he learned it was a security system feature and could be reset by leaving the key in the on position for 10 minutes and allowing the system to "re-learn". This fixed his issue,
Has anyone encountered this?
never heard of it, my security light comes on sometimes but thats it, just the light, no other probs. i guess it doesn`t cost or damage anything to try it!!
    tblt44
    tblt44
  • Who's Online   4 Members, 0 Anonymous, 608 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
