Parasitic Battery Drain
I have a different type problem I need some help with...
The vehicle is an '04 2500 4x4 8.1 Suburban.
I tow it behind my motorhome from jobsite to job site. To tow all 4 wheels down , there is a process you go through detailed in the owner's manual that shifts the tranny and transfer cases into neutral. You then put the gear shift in Park, turn the ignition to the ACC positiion (to unlock the steering wheel) and away you go. The big ol' b*tch tows great BTW.
The problem is that many times after towing 6-8 hours, the battery is dead on the 'Burb. I turn off everything like fans and radio but the dash lights are still on and the BCM is still active. From doing some research, I understand I need to pul the BCM fuse.
Only problem is I have no idea which fuse it is! I cannot disconnect the NEG cable from the battery since I have to power an auxiliary braking system in the 'Burb.
If anyone has additional suggestions to shut down unnecessary systems, I would appreciate it. I *really* need to now which fuse to pull for the BCM.
Thanks!
I will pull it in a minute from the Service Manual
Thanks Mike,
One guy told me he pulled the IGN0 fuse on his 2001 and it shut off the dash lights --- not so on mine.
Here is the whole darn page from the Service Manual:
The ones that I would want to pull would be the
TBC BATT
Truck Body Controller Battery Feed
and possibly the
IGN 0
PCM, TCM
TBC IGN 0
TBC 2C
TBC 2B
TBC 2A
gmLogoFlat.gif Service Information
2004 Chevrolet Chevy Suburban - 4WD | Chevrolet Tahoe/Suburban Owner Manual | Document ID: 864402 Fuses and Circuit Breakers The wiring circuits in your vehicle are protected from short circuits by a combination of fuses, circuit breakers and fusible thermal links. This greatly reduces the chance of fires caused by electrical problems.
Look at the silver-colored band inside the fuse. If the band is broken or melted, replace the fuse. Be sure you replace a bad fuse with a new one of the identical size and rating.
If you ever have a problem on the road and don't have a spare fuse, you can borrow one that has the same amperage. Just pick some feature of your vehicle that you can get along without - like the radio or cigarette lighter - and use its fuse, if it is the correct amperage. Replace it as soon as you can.
Instrument Panel Fuse Block
The fuse block access door is on the driver's side edge of the instrument panel. Pull off the cover to access the fuse block.
To remove fuses, hold the end of the fuse between your thumb and index finger and pull straight out.
You may have spare fuses located behind the fuse block access door. These can be used to replace a bad fuse. However, make sure it is of the correct amperage.
Fuses
Usage
RR Wiper
Rear Window Wiper Switch
SEO ACCY
Special Equipment Option Accessory
WS WPR
Windshield Wipers
TBC ACCY
Truck Body Controller Accessory
IGN 3
Ignition, Heated Seats
4WD
Four-Wheel Drive System, Auxiliary Battery
HTR A/C
Climate Control System
LOCK
Power Door Lock Relay (Lock Function)
HVAC 1
Inside Rearview Mirror, Climate Control System
L DOOR
Driver's Door Harness Connection
CRUISE
Cruise Control
UNLOCK
Power Door Lock Relay (Unlock Function)
RR FOG LP
Rear Fog Lamp (Export Only)
BRAKE
Anti-Lock Brake System
DRIVER UNLOCK
Power Door Lock Relay (Driver's Door Unlock Function)
IGN 0
PCM, TCM
TBC IGN 0
VEH CHMSL
Vehicle and Trailer High Mounted Stoplamp
LT TRLR ST/TRN
Left Turn Signal/Stop Trailer
LT TRN
Left Turn Signals and Sidemarkers
VEH STOP
Vehicle Stoplamps, Brake Module, Electronic Throttle Control Module
RT TRLR ST/TRN
Right Turn Signal/Stop Trailer
RT TRN
Right Turn Signals and Sidemarkers
BODY
Harness Connector
DDM
Driver Door Module
AUX PWR 2
Rear Cargo Area Power Outlets
LOCKS
Power Door Lock System
ECC
Rear Electronic Climate Control, Liftgate
TBC 2C
FLASH
Flasher Module
CB LT DOORS
Left Power Window Circuit Breaker
TBC 2B
TBC 2A
Center Instrument Panel Fuse Block
The center instrument panel utility block is located underneath the instrument panel, to the left of the steering column.
Device
Usage
SEO
TRAILER
Trailer Brake Wiring
UPFIT
Upfitter (Not Used)
SL RIDE
Ride Control Harness Connection
HDLR 2
Headliner Wiring Connector
BODY
Body Wiring Connector
DEFOG
Rear Defogger Relay
HDLNR 1
Headliner Wiring Connector 1
SPARE RELAY
Not Used
CB SEAT
Driver and Passenger Seat Module Circuit Breaker
CB RT DOOR
Right Power Window Circuit Breaker
SPARE
Not Used
INFO
Infotainment Harness Connection
Underhood Fuse Block
The underhood fuse block in the engine compartment on the driver's side of the vehicle near the battery. Lift the cover for access to the fuse/relay block.
See Engine Compartment Overview for more information on its location.
*1 -- Gasoline Engine and Fuel Injection Rail #2.
*2 -- Gasoline Engine and Fuel Injection Rail #1.
*3 -- Gasoline Engine; Oxygen Sensors.
*4 -- Gasoline Engine; Oxygen Sensors.
*5 -- PCM Ignition
Fuses
Usage
GLOW PLUG
Not Used
CUST FEED
Gasoline Accessory Power
STUD #1
Auxiliary Power (Single Battery and Diesels Only)/Dual Battery (TP2) Do not install fuse.
MBEC
Mid Bussed Electrical Center Power Feed, Front Seats, Right Doors
BLOWER
Front Climate Control Fan
LBEC
Left Bussed Electrical Center, Door Modules, Door Locks, Auxiliary Power Outlet--Rear Cargo Area and Instrument Panel
STUD 2
Accessory Power/Trailer Wiring Brake Feed
ABS
Anti-Lock Brakes
VSES/ECAS
Vehicle Stability
IGN A
Ignition Power
IGN B
Ignition Power
LBEC 1
Left Bussed Electrical Center, Left Doors, Truck Body Controller, Flasher Module
TRL PARK
Parking Lamps Trailer Wiring
RR PARK
Right Rear Parking and Sidemarker Lamps
LR PARK
Left Rear Parking and Sidemarker Lamps
PARK LP
Parking Lamps Relay
STARTER
Starter Relay
INTPARK
Interior Lamps
STOP LP
Stoplamps
TBC BATT
SUNROOF
Sunroof
SEO B2
Off-Road Lamps
4WS
Vent Solenoid Canister/Quadrasteer Module Power
RR HVAC
Rear Climate Control
AUX PWR
Auxiliary Power Outlet -- Console
IGN 1
Ignition Relay
PCM 1
Powertrain Control Module
ETC/ECM
Electronic Throttle Control, Electronic Brake Controller
IGN E
Instrument Panel Cluster, Air Conditioning Relay, Turn Signal/Hazard Switch, Starter Relay
RTD
Ride Control
TRL B/U
Backup Lamps Trailer Wiring
PCM B
Powertrain Control Module, Fuel Pump
F/PMP
Fuel Pump (Relay)
B/U LP
Back-up Lamps, Automatic Transmission Shift Lock Control System
RR DEFOG
Rear Window Defogger
HDLP-HI
Headlamp High Beam Relay
PRIME
Not Used
SIR
Supplemental Inflatable Restraint System
FRT PARK
Front Parking Lamps, Sidemarker Lamps
DRL
Daytime Running Lamps (Relay)
SEO IGN
Rear Defog Relay
TBC IGN1
Truck Body Controller Ignition
HI HDLP-LT
High Beam Headlamp-Left
LH HID
Not Used
DRL
IPC/DIC
Instrument Panel Cluster/Driver Information Center
HVAC/ECAS
Climate Control Controller
CIG LTR
Cigarette Lighter
HI HDLP-RT
High Beam Headlamp-Right
HDLP-LOW
Headlamp Low Beam Relay
A/C COMP
Air Conditioning Compressor
A/C COMP
Air Conditioning Compressor Relay
RR WPR
Rear Wiper/Washer
RADIO
Audio System
SEO B1
Mid Bussed Electrical Center, HomeLink, Rear Heated Seats
LO HDLP-LT
Headlamp Low Beam-Left
BTSI
Brake Transmission Shift Interlock System
CRANK
Starting System
LO HDLP-RT
Headlamp Low Beam-Right
FOG LP
Fog Lamp Relay
FOG LP
Fog Lamps
HORN
Horn Fuse
HORN
Horn Relay
W/S WASH
Windshield and Rear Window Washer Pump Relay
W/S WASH
INFO
OnStar/Rear Seat Entertainment
RADIO AMP
Radio Amplifier
RH HID
Not Used
EAP
Electric Adjustable Pedals
TREC
All-Wheel Drive Module
SBA
Supplemental Brake Assist
© 2008 General Motors Corporation. All rights reserved.
Here's a shot in the dark....and for Pete's sake, you mechanics chime in to correct me if this wouldn't work !!!!
Why would you not just plug in a positive wire from your motorehome to the 'burb's battery.
The motorhome's alternator should keep your battery charged and may actually run the aux braking.
Of course, you'll need the right gauge cable for the braking and possibly an additional fuse, but, I'm sure someone here can help with that.
Good luck
Good luck
Well, what I was going to originally suggest was to disconnect the battery, but he has duals.....It might help with a wire, but I am not sure
Good luck
You would need a negative as well as the positive going to the burb. However could you not fab some kind of harness that would power the aux brake as well as make the burbs brake lights work? I can't imagine it being too hard, just tie into the relays... although that would also use battery... Something to think about though.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
