Rain Sucks
Drove through the rain yesterday and got wet...
I mean the truck leaked on me
it is a extended cab 01 Sierra. The leak was coming in where the main door meets the x cab door on drivers side.
drip, drip, drip
annoying as heck.
my last truck never did this, how do I fix it?
I was hoping to avoid replacing weather strip
is there an adjustment that can be made?
No other adjustments, replace the rubber strip.
you can adjust it get a knife and slice right against the metal and get some 3m weatherstriping adhesive and lower the whole thing slightly and maybe that will work, ormaybe it needs to be raised in your case. Check for holes and tears, if you have any you will need to replace it anyways.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
