+/- On Dash Readings
jerr529
I placed this problem in general discussions, but maybe i should have posted here. My problem is my 09 1500 truck.On the dash the cluster for charging reads below center at about 11 o'clock now. When i bought my truck in march i was told when i asked about why it was below off center they said here and my tech that was normal well after few weeks it started to read above center, until yesterday it now is back below center. Well to me this seems weird ,im just worried that if this was winter and really cold i wouldny have enough volyage to start my truck. Is this a common occurance.or am i being paronoid.Other then that which the mech say is normal i really am worried something is wrong.
jerry
I'm not sure about the '09s and their gauges. If you questioning the vehicle's charging ability, put a multimeter on the battery and actually see if the truck is charging. You should see over 12v while the engine is running. If it is, the gauge is just off. If anything, the truck is under warranty.
My understanding of the voltage indication is that because of the Active Fuel Management (if your's is equipped) the alternator is all over the board and if the battery is OK at times it will shut off the alternator to conserve fuel.
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,197 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
