Vin Check Please?
VIN : 1GNFG15T951240199
VEHICLE INFORMATION
Merchandising Model : CG13406 -2005 EXPRESS PASSENGER VAN Warranty Start Date : 05/06/2005
BARS Order Type : 50 - FLEET
Delivering Dealer : ROBERTS AUTO PLAZA, INC.
PO BOX 470
PLATTE CITY , MO 64079-0470
(816) 858-3200
Selling Source : 13 - CHEVROLET
Site Code : 05258
Business Associate Code : 166305
Service Contract :
No
Branded Title :
No
Warranty Block :
No
PDI Status :
Paid
REQUIRED FIELD ACTIONS
Type
Number
Description
Posted Date
Status
RC
05113
SAFETY BELT BUCKLE INOPERATIVE ??
05/22/2006
Open
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description
Effective Date
Effective Odometer
End Date
End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY
05/06/2005
10 miles
05/06/2008
36010 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY
05/06/2005
10 miles
05/06/2011
100010 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM
05/06/2005
10 miles
05/06/2013
80010 miles
36/36000 FEDERAL EMISSION
05/06/2005
10 miles
05/06/2008
36010 miles
CLAIM HISTORY
R.O Date
R.O Number
Type
Labor Operation
Odometer Reading
07/07/2005
028194
C9040 - BELT, SEATBELT RETRACTOR (FRONT) (RIGHT) - REPLACE 12652 miles
04/29/2005
A40199
I
Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
? 1998-2005 General Motors Corporation. All Rights Reserved.
VIN 1GNFG15T951240199
VEHICLE BUILD
Gross Vehicle Weight Rating : 3269 kg (7208 lb) Order Number : JCCVQK
Build Date : 04/29/2005 Build Plant : 15106
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AJ1 - DEEP TINTED GLASS AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAG
AR7 - FRONT RECLINING BUCKET SEATS AU3 - POWER DOOR LOCKS
AXP - MPV VIN IDENT POSITION A17 - SIDE BODY SWING OUT WINDOW
A18 - REAR SIDE WINDOW, SWING-OUT A31 - POWER WINDOWS
B38 - FULL FLOOR COVERING CAP - COMPETITIVE ASSISTANCE PROGRAM UNIT
C36 - AUXILIARY REAR HEATER C5Z - 7,200 LB GVW
C60 - AIR CONDITIONING C69 - REAR AIR CONDITIONING
DE2 - MIRRORS, EXTERIOR DH6 - ILLUMINATED RH VISOR MIRROR
D31 - INTERIOR REARVIEW MIRROR EVA - EVAP EMISSION REQUIREMENT
E2C - ORDER TO DELIVERY - EXPEDITE E24 - DOOR SIDE CARGO, HINGED
FE9 - FEDERAL EMISSIONS FLT - FLEET PROCESSING OPTION
GU6 - REAR AXLE 3.42 RATIO JH5 - HYD POWER DISC BRAKES
KD1 - TRANS OIL COOLING SYSTEM KG3 - 145 AMP ALTERNATOR
LM7 - 5.3L V8 ENGINE M30 - 4 SPEED AUTO TRANSMISSION
NA1 - LIGHT DUTY EMISSIONS NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
R9U - GM ACCESS - AUTOBOOK IDENTIFIER TFD - RETAIL AMENITY DELETE
TR9 - AUXILIARY LIGHTING UM7 - ETR AM/FM STEREO WITH SEEK/SCAN AND DIGITAL CLOCK
U73 - FIXED MAST ANTENNA VK3 - FRONT LICENSE PLATE MOUNT
VQ2 - FLEET ORDERING AND ASSISTANCE VXS - COMPLETE VEHICLE LABEL
VZ5 - FLT--RENZENBERGER, INC. V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
WEN - PLANT CODE-WENTZVILLE,MO XNK - TIRES,FRONT P245/75R16, ALL SEASON, BLACKWALL
X88 - CHEVROLET CONVERSION YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD5 - BASE FRONT SPRING YD6 - BASE REAR SPRING
YK6 - SEO IDENTIFICATION YNK - TIRES,REAR P245/75R16, ALL SEASON, BLACKWALL
ZNK - TIRE,SPARE P245/75R16, ALL SEASON, BLACKWALL, LOCATED AT REAR UNDERBODY OF VEHICLE ZP8 - EIGHT PASSENGER SEATING
ZQ2 - POWER LOCKS & POWER WINDOWS ZW9 - STANDARD BODY OR CHASSIS CAB
ZY1 - SOLID PAINT 1SA - 1SA PACKAGE
1SZ - EXPRESS ACCESS DISCOUNT 50U - SUMMIT WHITE
6YZ - SPRING COMPTR SELECT FRT LH 7YZ - SPRING COMPTR SELECT FRT RH
9J6 - STEERING COLUMN, TILT 93I - MED. DARK PEWTER INTERIOR TRIM
93W - MEDIUM DARK PEWTER
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : W - CPC/DDA ROMULUS, MICHIGAN
Part/Num Broadcast : WCA Traceability : 051095142
Date Scanned : 04/29/2005 Time Scanned : 19.59.00 Scan Station : 08
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : T2T Traceability : NB0240965
Date Scanned : 04/29/2005 Time Scanned : 19.30.00 Scan Station : 06
Component Code : 61 - TRANSMISSION
Source Plant : Y - HYDRAMATIC TOLEDO, OHIO
Part/Num Broadcast : 5CHD Traceability : 41249388
Date Scanned : 04/29/2005 Time Scanned : 20.02.00 Scan Station : 09
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : 9
Part/Num Broadcast : YHZP Traceability : 051158WN1
Date Scanned : 04/30/2005 Time Scanned : 00.52.00 Scan Station : 19
Component Code : 87 - BODY CONTROL MODULE
Source Plant : M
Part/Num Broadcast : 6876 Traceability : 25115M5BS
Component Code : 92 - BRAKE PRESSURE MODULATOR VALVE ASSEMBLY
Source Plant : K - KELSEY-HAYES JASPER, INDIANA
Part/Num Broadcast : 4558 Traceability : 00003040
Date Scanned : 04/29/2005 Time Scanned : 20.28.00 Scan Station : 15
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 8212 Traceability : 1FEH46K
Date Scanned : 04/29/2005 Time Scanned : 22.15.00 Scan Station : 12
Component Code : AD - IR-SENSOR-FORWARD
Source Plant : X - DELCO ELECTRONICS SINGAPORE
Part/Num Broadcast : 2155 Traceability : 5094J0PUP
Component Code : AL - IR-MODULE ASM-I/P
Part/Num Broadcast : 1615 Traceability : 6EEKN0N
Date Scanned : 04/29/2005 Time Scanned : 19.13.00 Scan Station : 05
Component Code : AS - SENSING DIAGNOSTIC MODULE
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : 6489 Traceability : 251083KQ4
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1ZZ Traceability : 2010552
Date Scanned : 04/23/2005 Time Scanned : 04.02.00 Scan Station : N/A
Component Code : CC - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1XX Traceability : 1373284
Date Scanned : 04/27/2005 Time Scanned : 03.30.00 Scan Station : N/A
Component Code : CD - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1XR Traceability : 1355566
Date Scanned : 04/28/2005 Time Scanned : 17.17.00 Scan Station : N/A
Component Code : CF - SEQ NUM (FLEX) PAINT PROCESS
Source Plant : N/A
Part/Num Broadcast : 1XP Traceability : 1323562
Date Scanned : 04/28/2005 Time Scanned : 20.39.00 Scan Station : N/A
Component Code : CG - SEQ NUM (FLEX) PAINT PROCESS
Source Plant : N/A
Part/Num Broadcast : 1XN Traceability : 1370586
Date Scanned : 04/28/2005 Time Scanned : 21.16.00 Scan Station : N/A
Component Code : CK - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1XL Traceability : 1338281
Date Scanned : 04/28/2005 Time Scanned : 22.07.00 Scan Station : N/A
Component Code : CM - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1XJ Traceability : 1383486
Date Scanned : 04/28/2005 Time Scanned : 22.23.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1GA Traceability : 1369672
Date Scanned : 04/29/2005 Time Scanned : 17.11.00 Scan Station : N/A
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 05/06/2005 Delivery Type : 035 - BUSINESS/ORGANIZATION Delivered Odometer : 10 miles
PO BOX 470
(816) 858-3200
Delivery Selling Source : 13 - CHEVROLET
Delivery Site Code : 05258
INVOICE INFORMATION
Invoice Date : 04/29/2005
Site Address : ROBERTS AUTO PLAZA, INC.
PO BOX 470
(816) 858-3200 Selling Source : 13 - CHEVROLET
Site Code : 05258
SHIP-TO INFORMATION
Ship-To Date : N/A
PO BOX 470
Site Code : 05258
that vehicle has an open recall:
#05113C: Product Safety - Safety Belt Buckle Inoperative - (Apr 23, 2008)
gmLogoFlat.gif Service Information
Document ID: 2104965 #05113C: Product Safety - Safety Belt Buckle Inoperative - (Apr 23, 2008)
Subject:05113C -- SAFETY BELT BUCKLE INOPERATIVE
Models:2003-2006 CHEVROLET EXPRESS
2003-2006 GMC SAVANA
Additional population has been added to this recall. Please discard all copies of bulletin 05113B, issued June 2006.
Condition
General Motors has decided that a defect, which relates to motor vehicle safety, exists in certain 2003-2006 Chevrolet Express and GMC Savana vehicles. Some of these vehicles have safety belt buckles that may not latch or unlatch. If a safety belt buckle does not latch, that seating position should not be used and another seating position should be used if possible. If a safety belt buckle does not unlatch, it may require cutting of the belt to release the occupant. Occupants in a vehicle should always wear a safety belt or an increased risk to personal injury can occur in the event of a vehicle crash.
Correction
Dealers are to inspect the safety belt buckles and replace either the buckle cover or the entire buckle assembly.
Vehicles Involved
Involved are certain 2003-2006 Chevrolet Express and GMC Savana vehicles built within these VIN breakpoints:
Year
Division
Model
From
Through
2003
Chevrolet
Express
31100003
31238955
2004
Chevrolet
Express
41100001
41248485
2005
Chevrolet
Express
51100001
51269726
2006
Chevrolet
Express
61100002
61156911
2003
GMC
Savana
31100002
31905189
2004
GMC
Savana
41100002
41914037
2005
GMC
Savana
51100003
51913350
2006
GMC
Savana
61100021
61156572
Important: Dealers should confirm vehicle eligibility through GMVIS (GM Vehicle Inquiry System) prior to beginning recall repairs. [Not all vehicles within the above breakpoints may be involved.]
For US and Canada: For dealers with involved vehicles, a Campaign Initiation Detail Report (CIDR) containing the complete vehicle identification number, customer name and address data has been prepared and will be loaded to the GM DealerWorld (US) Recall Information, GMinfoNet (Canada) Recall Reports. Dealers will not have a report available if they have no involved vehicles currently assigned.
For Export: For dealers with involved vehicles, a Campaign Initiation Detail Report containing the complete vehicle identification number, customer name and address data has been prepared, and is being furnished to involved dealers. Dealers will not receive a report with the recall bulletin if they have no involved vehicles currently assigned.
The Campaign Initiation Detail Report may contain customer names and addresses obtained from Motor Vehicle Registration Records. The use of such motor vehicle registration data for any purpose other than follow-up necessary to complete this recall is a violation of law in several states/provinces/countries. Accordingly, you are urged to limit the use of this report to the follow-up necessary to complete this recall.
Parts Information
Parts required to complete this recall are to be obtained from General Motors Service Parts Operations (GMSPO). Please refer to your "involved vehicles listing" before ordering parts. Normal orders should be placed on a DRO = Daily Replenishment Order. In an emergency situation, parts should be ordered on a CSO = Customer Special Order.
Part Number
Description
Quantity/Vehicle
19149481
Cover, Seat Belt Tr (Bkl Si) (Neutral)
As Req'd
19149482
Cover, Seat Belt Tr (Bkl Si) (Pewter)
As Req'd
Service Procedure
Seat Belt Buckle Inspection Procedure
Seat Belt with Pre-Tensioner
Seat Belt without a Pre-Tensioner
Important: This procedure is to be performed on all seat belts (front and rear) without a pre-tensioner. Seat belts with a pre-tensioner are not involved.
Important: Front seat belts with a pre-tensioner are not involved in this recall. The remaining seat belts in the vehicle must be inspected.
  1. Install the seat belt latch into the buckle.
  2. Check for proper latching and unlatching.
    If the seat belt buckle will not latch or unlatch, the buckle assembly requires replacement.
    If the seat belt buckle latches and unlatches correctly, the seat belt buckle cover requires replacement.
  3. Repeat Steps 1 and 2 for all remaining non-pre-tensioner seat belts in the vehicle, including rear seats.
Seat Belt Buckle Assembly Replacement
Refer to the appropriate SI Document for replacement instructions
• Front Seat Belt Buckle Replacement
• Rear Seat Belt Buckle Replacement
Seat Belt Buckle Cover Replacement
  1. On front seats, lift the buckle sleeve at the bottom to expose the bolt.
  2. On front seats, remove the seat belt buckle retaining bolt from the seat.
  3. On front seats, disconnect the buckle sensor wire.
  4. On front seats, slide the buckle sleeve down to expose the buckle.
  5. Insert the latch into the buckle and leave it inserted throughout the cover replacement procedure.
    Buckle Shown with Cover Removed for Clarity
    (1)Front of Buckle (2)Rear of Buckle (3)Clip Location
  6. Remove the buckle cover.
    6.1. Holding the lower half of the buckle in one hand, put the thumb of the opposite hand in the area where the belt loops through the buckle..
    6.2. Using the thumb, push the cover over and then up and away from the lower half; the clip should release.
Push the cover in the opposite direction to release the other side.
6.4. Lift the back of the cover to disengage the front.
<li type="1">Install the new cover.
7.1. Engage the end near the red pushbutton.
7.2. Press down firmly on the back end to fasten the cover; you should hear an audible click.
7.3. Inspect for complete seating and flushness of the mating seams of the upper and lower cover.
<li type="1">Remove, insert, and remove the latch from the buckle a second time to ensure proper operation. <li type="1">On front seats, slide the buckle sleeve back into place. <li type="1">On front seats, reconnect the buckle sensor wire. <li type="1">On front seats, install the seat belt buckle retaining bolt to the seat. Tighten
Tighten the seat belt buckle retaining bolt to 52 N·m(38 lb ft).
<li type="1">On front seats, be sure that the buckle sleeve is returned to the original position. <li type="1">Repeat this procedure on all buckles identified in the inspection procedure.
Customer Reimbursement - For GM US
All customer requests for reimbursement for previous repairs for the recall condition will be handled by the Customer Assistance Center, not by dealers.
A General Motors Customer Reimbursement Procedure and Claim Form is included with the customer letter.
Important: (For GM US Only) Refer to the GM Service Policies and Procedures Manual, section 6.1.12, for specific procedures regarding customer reimbursement and the form.
Customer Reimbursement - For Canada and Export
Customer requests for reimbursement of previously paid repairs to correct the recall condition are to be submitted to the dealer by April 30, 2009.
All reasonable customer paid receipts should be considered for reimbursement. The amount to be reimbursed will be limited to the amount the repair would have cost if completed by an authorized General Motors dealer.
When a customer requests reimbursement, they must provide the following:
• Proof of ownership at time of repair.
• Original paid receipt confirming the amount of repair expense(s) that were not reimbursed, a description of the repair, and the person or entity performing the repair.
Claims for customer reimbursement on previously paid repairs are to be submitted as required by WINS.
Important: Refer to the GM Service Policies and Procedures Manual, section 1.6.2, for specific procedures regarding customer reimbursement verification.
Courtesy Transportation - For US and Canada
The General Motors Courtesy Transportation Program is intended to minimize customer inconvenience when a vehicle requires a repair that is covered by the New Vehicle Limited Warranty. The availability of courtesy transportation to customers whose vehicles are within the warranty coverage period and involved in a product recall is very important in maintaining customer satisfaction. Dealers are to ensure that these customers understand that shuttle service or some other form of courtesy transportation is available and will be provided at no charge. Dealers should refer to the General Motors Service Policies and Procedures Manual for courtesy transportation guidelines.
Claim Information
Submit a Product Recall Claim with the information indicated below:
Repair Performed
Part Count
Part No.
Parts Allow
CC-FC
Labor Op
Labour Hours
Net Item
Inspect Both Front Seats, and if necessary, Replace Driver's Seat Belt Cover or Buckle Assembly
0-1
MA-96
V1434
0.2
N/A
Add: Replace Seat Belt Cover or Buckle Assembly - Passenger Front Seat, if equipped & required
Add: Replace Seat Belt Cover on 1 to 3 Rear Seats
1-3
0.1
Add: Replace Seat Belt Cover on 4 to 6 Rear Seats
4-6
0.2
Add: Replace Seat Belt Cover on 7 to 10 Rear Seats
7-10
0.3
Add: Replace Seat Belt Cover on 11 to 13 Rear Seats
11-13
0.4
Add: Replace Rear Buckle Assembly - Each
1-13
0.1
Courtesy Transportation for Vehicles Within the New Vehicle Limited Warranty (US & Canadian GM Dealers)
N/A.
N/A
N/A
MA-96
N/A
Customer Reimbursement (Canadian & Export Dealers/US CAC)
N/A
N/A
N/A
MA-96
V1435
0.2
* The "Parts Allowance" should be the sum total of the current GMSPO Dealer net price plus applicable Mark-Up or Landed Cost Mark-Up (for Export) for the seat belt cover, and if required, the buckle assembly needed to complete the repair.
** Submit courtesy transportation using normal labor operations for courtesy transportation as indicated in the GM Service Policies and Procedures Manual for vehicles within the New Vehicle Limited Warranty.
*** The amount identified in the "Net Item" column should represent the actual dollar amount for courtesy transportation.
**** The amount identified in the "Net Item" column should represent the dollar amount reimbursed to the customer.
Refer to the General Motors WINS Claims Processing Manual for details on Product Recall Claim Submission.
Customer Notification - For US and Canada
General Motors will notify customers of this recall on their vehicle (see copy of customer letter included with this bulletin).
Customer Notification -- For Export
Letters will be sent to known owners of record located within areas covered by the US National Traffic and Motor Vehicle Safety Act. For owners outside these areas, dealers should notify customers using the attached sample letter.
Dealer Recall Responsibility - For US and Export (US States, Territories, and Possessions)
The US National Traffic and Motor Vehicle Safety Act provides that each vehicle that is subject to a recall of this type must be adequately repaired within a reasonable time after the customer has tendered it for repair. A failure to repair within sixty days after tender of a vehicle is prima facie evidence of failure to repair within a reasonable time. If the condition is not adequately repaired within a reasonable time, the customer may be entitled to an identical or reasonably equivalent vehicle at no charge or to a refund of the purchase price less a reasonable allowance for depreciation. To avoid having to provide these burdensome remedies, every effort must be made to promptly schedule an appointment with each customer and to repair their vehicle as soon as possible. In the recall notification letters, customers are told how to contact the US National Highway Traffic Safety Administration if the recall is not completed within a reasonable time.
Dealer Recall Responsibility - All
All unsold new vehicles in dealers' possession and subject to this recall must be held and inspected/repaired per the service procedure of this recall bulletin before customers take possession of these vehicles.
Dealers are to service all vehicles subject to this recall at no charge to customers, regardless of mileage, age of vehicle, or ownership, from this time forward.
Customers who have recently purchased vehicles sold from your vehicle inventory, and for which there is no customer information indicated on the dealer listing, are to be contacted by the dealer. Arrangements are to be made to make the required correction according to the instructions contained in this bulletin. A copy of the customer letter is provided in this bulletin for your use in contacting customers. Recall follow-up cards should not be used for this purpose, since the customer may not as yet have received the notification letter.
In summary, whenever a vehicle subject to this recall enters your vehicle inventory, or is in your dealership for service in the future, you must take the steps necessary to be sure the recall correction has been made before selling or releasing the vehicle.
Dear General Motors Customer:
This notice is sent to you in accordance with the requirements of the National Traffic and Motor Vehicle Safety Act.
General Motors has decided that a defect that relates to motor vehicle safety exists in certain 2003-2006 model year Chevrolet Express and GMC Savana vehicles. As a result, GM is conducting a safety recall. We apologize for this inconvenience. However, we have taken this action for your safety and continued satisfaction with our products.
IMPORTANT
• Your vehicle is involved in safety recall 05113.
• Schedule an appointment with your GM dealer.
• This service will be performed for you at no charge.
Why is your vehicle being recalled?
What will we do?
Your GM dealer will inspect the safety belt buckles and replace either the buckle cover or the entire buckle assembly. This service will be performed for you at no charge . It is likely that your dealer will need your vehicle longer than the actual service correction time of approximately 15 to 50 minutes because of service scheduling requirements.
If your vehicle is within the New Vehicle Limited Warranty your dealer may provide you with shuttle service or some other form of courtesy transportation while your vehicle is at the dealership for this repair. Please refer to your Owner's Manual and your dealer for details on courtesy transportation.
What should you do?
You should contact your GM dealer to arrange a service appointment as soon as possible. Bring the enclosed customer reply form with you when you visit your dealer. The form identifies the repairs required. If you no longer own this vehicle, please let us know by completing the form and mailing it back to us.
Did you already pay for this repair?
The enclosed form explains what reimbursement is available and how to request reimbursement if you have paid for repairs for the recall condition.
Do you have questions?
If you have questions or concerns that your dealer is unable to resolve, please contact the appropriate Customer Assistance Center at the number listed below. More information about this recall can be found at the Owner Center at MyGMLink, http://www.gm.com/recall.
Division
Number
Text Telephones (TTY)
Chevrolet
1-800-630-2438
1-800-833-2438
GMC
1-866-996-9463
1-800-462-8583
Guam
1-671-648-8650
Puerto Rico - English
1-800-496-9992
Puerto Rico - Español
1-800-496-9993
Virgin Islands
1-800-496-9994
If after contacting your dealer and the Customer Assistance Center, you are still not satisfied we have done our best to remedy this condition without charge and within a reasonable time, you may wish to write the Administrator, National Highway Traffic Safety Administration, 400 Seventh St., SW, Washington DC 20590, or call the toll-free Vehicle Safety Hotline at 1.888.327.4236 (TTY 1.800.424.9153), or go to http://www.safercar.gov.
Federal regulation requires that any vehicle lessor receiving this recall notice must forward a copy of this notice to the lessee within ten days.
Scott Lawson
General Director,
Customer and Relationship Services
Enclosure
05113
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gif WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
  • 3 years later...
Please see your dealer. This information is no longer allowed to be posted online.
