Xm And Onstar Antenna Removal
I have searched the forums for anything about removing these stock antennas (which I think are just way to big and annoying, and I believe one or both are allowing water into my Tahoe which leaks on me through the Onstar mic in the headliner right over the driver seat). I have a full Onstar install that I want to remove as I never plan on using it, and I hear the 2003 Onstar will not work anymore after a certain date this year without an upgrade, which I don't see myself paying for. I also installed a brand new aftermarket doube DIN stereo and have an XM tuner to pair with it. I do not wish to use the stock XM antenna because it is in a poor position to blend into the vehicle and looks strange with two different antennas that I don't plan on using. The new XM unit came with one of the small magnetic antennas that I plan to run all the way back to the rear hatch.
Anyways, I haven't looked yet since I got the Tahoe but from reading posts here, these antennas have holes drilled in my roof (ugh). Obviously I will need to fill those sand and paint and all that fun stuff. Has anyone done this?
If it is working now, it will work.
Avalanche — 2003*, 2004*, 2005
Cavalier — 2003*, 2004*, 2005*
Cobalt — 2005*
Colorado — 2004*, 2005
Corvette — 2005*
Equinox — 2005*
Express — 2003*, 2004*, 2005
Impala — 2002*, 2003*, 2004*, 2005
Malibu — 2004*, 2005*
Monte Carlo — 2002*, 2003*, 2004*, 2005
Silverado — 2003*, 2004*, 2005
Suburban — 2003*, 2004*, 2005
Tahoe — 2003*, 2004*, 2005
TrailBlazer — 2002*, 2003*, 2004*, 2005
TrailBlazer EXT — 2002*, 2003*, 2004*, 2005
Uplander — 2005
Venture — 2003*, 2004*, 2005*
*This vehicle may require a digital upgrade for service after 12/31/07.
Cobalt — 2005*
Corvette — 2005*
Equinox — 2005*
Uplander — 2005
I don't know if it is working or not. I don't want it so I haven't used it.
    RichardRS
    RichardRS
  • Who's Online   4 Members, 0 Anonymous, 806 Guests (See full list)
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
