2003 Silverado Speakers
Hello,
I have a stock system. The sound from the front speakers has started to sound bad (rattleing). I have no experience with car audio installation.
When my truck was new, I thought the sound was awesome. Should I just get the same speakers from the dealer or can someone suggest aftermarket?
I am pretty handy, I feel confident I can do the install, as long as I don't have to do additional wiring, soldering, etc. I want to keep the price down, so a shop would be last resort.
Please help!
Hello,
Please help!
Aftermarket always sounds better. I would go to Crutchfield's web site and plug in your truck, see what size speakers you will need an what not. If you can swing the money, I would buy an aftermarket head unit as well too. But if you have the factory XM you most likely won't be able to hook it up to the new head unit, if you have/use OnStar you will need a special adapter that Crutchfield does sell (only $50 with radio purchase).
Thanks for the reply. I'll check out Crutchfield. I don't have the $$$ for a new radio. It works, so I can't justify that purchase.
There are alot of choices..... does more $$$ mean better?
Also I do not have OnStar or the Bose system.
Thanks for the reply. I'll check out Crutchfield. I don't have the $$ for a new radio. It works, so I can't justify that purchase.
There are alot of choices..... does more $$ mean better?
Usually the more money you spend of course the better the system can be. I am not sure how much the dealer would charge for replacing the speaker(s), but it may be less than just replacing the speakers yourself with aftermarket and keeping your stock head unit.
In my opinion and experience, Infinity seems to be a great choice of speaker. I have also had $50 Kenwood speakers though that weren't that bad.
What ever you do , do not go with stock. The stock speakers are just cheap paper speakers.....
When i replaced them on my colorado i was very suprised as the cheap quality... heres a pic on the back of the speaker... check out the high wattage :lol:
Go to crutchfield... put in your truck info, they will tell u what speakers u need that will fit and give you all price options... all u need is some decent but not too high of power handling speakers ... nicer ones will have a built in directional tweeter so u can aim the sound to your ears.
I always had great luck with Polk audio (had them in my old s10)...
in my colorado i had kickers... they were awesome too..
heres a pic...
they sounded great and the max watt handling was like 90.. so the stock radio sounded great on em and didnt have to worry bout too much power.
Also, if you priced out the factory speakers, you would be suprised at how much they want for that junk..
One more thing bout crutchfield. i always liked them because they give u free direction on how to remore your door panel w/ detailed instructions on where screws are and where to pull from so u dont break it.. plus they give u the wire harnes adapter so u dont have to mess with soldering new speaker wires...!
:dunno:
I would suggest going with Infinity Reference speakers. It's what Crutchfield suggested for me when I was looking to upgrade. And the Infinity's are perfect if you are not going to amp them. And it sounds like your not. They have a high sensitivity rating. I replaced all 4 door speakers with them and was very impressed.
+1
Not if you buy crap. I had a pair of Blaupunkt speakers that didn't sound any better than stock.
I wouldn't bother with expensive speakers if you're only going to be using them with the factory radio. Before you start spending lots of money on speakers, you need to worry about an amplifier and sound deadening first.
BTW, Crutchfield is a great place to buy from (free install gear, instructions, etc.) but they are also overpriced. I've had good luck with SonicElectronix.com and OnlineCarStereo.com, check them out too.
Can you give us a price range to work with?
All I want are some basic speakers-front/rear...I don't want to solder, modify wiring or get extra amps, crazy bass, enter a stereo contest....... I'm just keeping it simple. My stock speakers are getting worse....
Budget is $150.
Thanks!
Just so you know, unless you buy an additional bracket and adapter, you will have to drill holes in your door and will have to cut off the factory speaker wire terminal. Normally, I'd be against cutting factory wiring, but since you most likely won't put the stock speakers back in and the new terminals will fit most aftermarket speakers, it's not such a big deal to me.
If you buy through Crutchfield, you will get these adapters for free though. However, I recommend you drill the holes in your doors anyways because the plastic adapter brackets don't hold the speakers securely at all and make a terrible seal.
If you were fine with the stock speakers and just want some good replacements, I recommend these Pioneer speakers at Crutchfield, SonicElectronix, and OnlineCarStereo.com. They will offer a slight improvement over stock and won't complain about being run off of a factory stereo. Not to mention, it doesn't blow your entire budget. IMO, it would be pointless to blow $150 on nice speakers and then connect them to a factory headunit. :D
Thunderstruck-Thanks for taking the time to lookup those speakers for me!
Will/should I use the same speakers for the rear? Or do you suggest something different.
Also, I noticed the front door seems to have 2 speakers for each side. These single Pioneer speakers do what 2 of the stock speakers do?
Thanks again!!!
BigCypress let me know what you go with and how the new ones sound if u dont mind that is. i have an 04 and am looking at speakers for my truck as well but i dont have the cash to spend on a new head unit yet, because i want to keep my steering wheel controls. if it will help i wouldnt mind a good combo of an amp and door speakers so of course and suggestions would be helpful.
Do you have a regular cab, extended cab, or crew cab? Regular and extended cabs use 4"x6" speakers for the rear, while crew cabs have 6-3/4" speakers like the front speakers.
I personally have stopped running rear speakers. They make the sound seems like it's coming from behind you, I like the sound to come from in front of me. You wouldn't turn your back to the stage at a concert would you?
They aren't always good for passengers either because they are usually mounted in terrible locations. I have a OBS extended cab, and when I still had rear speakers my passengers always complained about how the rear speakers were right next to their ears.
The smaller stock speaker is a tweeter. You really don't need it anymore because the Pioneer has it's own tweeter mounted in the center. However, you can leave the stock tweeter connected if you like.
Thunderstruck:
I have the extended cab. Again thanks for the advice. I want to get the speakers you suggested this week. I want this to go smooth, so, I am going to use Crutchfield, especially since they provide connectors (right)?
I am going to keep the rear speakers hooked up for now. I enjoy the sound of the stock head unit/simplicity and I ride solo most of the time. If I did want to replace the rears, can you suggest a 4x6?
Once again I really appreciate youre help.
Silverz71: I am following Thunderstrucks advice.
I will definitely let everyone know how the install and sound is when I get these guys installed.
Once again, THANK YOU.
Glad we could help.
Thunderstruck:
Crutchfield should give you the connectors so you don't have to cut factory wiring.
These will work fine as a factory replacement: http://www.crutchfield.com/App/Product/Ite...4642&tp=105
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 640 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
