Buddies New F150 Limited
punmax
Picked up this thing fully loaded for 35000 American and brought it back to Canada. Beautiful truck.
Never been a huge fan of Fords, not feeling the color scheme with the rims. Your truck looks a million times better. Funny loaded Mark LT's go for around that and look better, just my opinion.
This truck was 30, but my friend had to pay GST and PST at the border, so it ended up being close to 35.
That is a very nice truck :cheers:
Not a fan of white though and tell him to remove those tacky "Limited" letters off the side of the bed. :D
I also do not care for the interior.
But yeah, that truck would definitely be my 2nd choice.
Dude, tell him to take it back. The windshield wipers are obviously broken!!!
Not a fan of white, or fords, so white fords are a big no no to me. But, I would drive it as a get away vehicle, so long as I could ditch it later!
I'd take a horse and carraige before I would ever consider a Furd again...
Not a fan of white though and tell him to remove those tacky "Limited" letters off the side of the bed. :cheers:
+1 ka-jillion
Looks schmooks. what's important about a truck is:
How does it do in a collision with a house? Silverados are kicking the rest of the manufacturers butts in that department!
least...that's what i hear :cheers:
I have a buddy with a red F150 Crew and I have to admit that it is a nice truck. His has the 5.4 and the power doesn't compare to our V8s... at least not in his. Off the line it is pretty slow and it rides rougher than my Sierra. It is a good looking truck... for a Ford. He's getting about 16 mpg so that is about the same. The only issues I know of are 2 sets of rear brakes and leaking rear axle seals (related I'm sure) that he has had to have replaced.
It's still a FORD. :cheers:
I saw one of these in person the other day. It's a damn nice looking truck and the wheels really do look nice. The stupid ass lettering has to go though.
Definitely not digging the lettering on the side of the bed. I think the wheels might look better if they had more meat on those tires. By the way : Since they plastered "LIMITED" so big on the side... Just what the heck does that get you? (Other than a Ford, I mean.)
