Buying A New(er) Gmc, Help Me Out!
well, i found a bigger truck that im workin on buying now. i currently have a regular cab dakota that just isnt cuttin it anymore. I found an 05 Sierra SLE, extended cab z71 with a 5.3. The exterior is almost perfect and the interior is mint, the truck has 51k miles on it. the price tag is $13,400. i was a little weary, but the carfax came back as a local guy, 1 owner, no wrecks or anything. so my question is, is there anything i should look for or change on the truck when i get it? the list so far is cold air intake, chip, true dual exhaust, aftermarket tail lights (i dont like the factory ones), tinted windows and a remote starter.
ive done a bit of research on these trucks. ive heard about a steering shaft problem, but this truck seems to steer solid with no clunks or binding. i test drove an 04 last year that made some weird noises, and it turned out to be some kind of gauge cluster problem that requires replacement of the entire thing. this truck doesnt do it. the brakes, from what i understand, were changed in 05 and didnt have all the problems they did in 03 and 04. this truck has the aluminum block motor, what is the hp spec on it? ive heard 325 in the aluminum block, and 310 in the cast block models. is that right?
im pretty much just lookin to absorb as much info on these trucks as i possibly can, and so far it seems like im in the right place!
310 for the "L33" aluminum block 5.3
295 for the "LM7" or "L59" iron block 5.3
For an '05
HP is 295 cast iron block and 310 aluminum block. In '07 with the NBS they got a HP bump. Once you go GM, you will never look back!
edit: Rich...you're too fast! :lol: oh well, he knows twice as much more than anyone here anyway
The '05s have bigger front calipers/rotors and rear drums instead of the rear discs the '99-'04s had,There were not any "major" problems with the '03-'04 brakes,although the right-rear inner pad on the back did tend to wear before the other three did.
The '05-up trucks do have a "firmer" pedal feel compared to the '04-older trucks.
For an '05
Sorry Ed :D
thanks guys. im lookin into tires pretty soon, too. i want a nice stance, so i was thinkin of on the cheap, goin with a leveling kit first, then maybe a lift. ive seen levelin kits which is just the torsion keys, and then there are the kits with the keys and rear blocks to do a 3"/1" raise. isnt that a bit much to be crankin your torsion bars? and what size tires could i stuff under each kit? im keepin the 17 inch rims because they look pretty nice i think. i found a set of 295/75R17 nitto terra grapplers for pretty cheap, but i dont think those will fit without a suspension lift, will they? thanks again
    250.3k
    RobbertClaus
    RobbertClaus
  • Who's Online   3 Members, 0 Anonymous, 453 Guests (See full list)
    • No I didn’t watch a video of a person who analyzes oil for a living explain general oil usage. For clarity I did ask my brothers one who runs our equipment business. The other who runs our old ROW business about oil usage. Nothing has changed since I retired. Their personal vehicles or work vehicles use no oil. Not enough to see on the oil checking device. Then I pondered. I like to ponder. In this extended oil changing world with oil change countdowns or lights. If engines used say a qt every 2500 miles or up to even 4000 miles. With oil changes reaching as high as 15000 miles. Normal for most people is eight to ten. Vehicles should potentially be seizing up all over the place. Especially in hilly terrain. Just how many people actually check their oil? Maybe 10 percent. Those are the people that probably change their oil early. I like to research used car listings. I have five favorite dealers I check. They all list carfax with their listing. It’s rare to see vehicles with anything but extended oil changes. Transmission service, forget about it. I’ve seen Honda and Toyota certified vehicles up to 100K miles and ten years old. With nothing but normal maintenance. Isn’t nice we all have different experiences and believe our way is the best. You certainly get backup for whatever you believe. Life would be boring otherwise.
    • Interesting rumor. Dealers near me have been tight-lipped so far, but if this reveal actually happens next week, I'm really hoping they finally give the HD a proper interior overhaul. The competition has been eating their lunch in the cabin department for a while now.
    • There are a few good takeaways in that video that pertain to this thread, certainly the possibility of the oil control rings having buildup, the fuel injectors and how clean or not that they are ending up affecting the pistons rings carbon buildup, and the fact that its normal up to a point for a given engine to use some oil, and that the oil quality that is being utilized is part of that ring clogging up issue as well.   I was talking with a neighbor yesterday who has a baby LZ0 duramax and he had bought it slightly used but it does consume some oil and he has switched over to 5W-30 Euro spec oil and in this case that never made a difference in consumption over the factory 0W-20 recommendation. He finds it uses a quart in about 3500 miles and as he goes a ways over that distance he adds oil to full and goes another 1000 miles or so and then changes oil and is typically at 40% or so left on the oil monitor at that point with his use case of quite a lot of highway miles and more limited in short run use. I don't know what other LZ0 engines are doing for oil consumption but that is what his is doing.
    • I dont care what Lake says. Goodnight.
    • Ok well I guess Lake disagrees with me on a few points. I call oil consumption pretty basic. Rudimentary. He calls it "really complicated." I think 1qt consumed in 3k miles is a lot. He says that's normal. In 22 minutes, he'll use his natural talent to explain oil consumption to anyone watching this video. He covers everything from obvious engine damage to how normally functioning healthy engines consume oil by design. Lake explicitly states how you drive will impact oil consumption.   Shut up and watch:
