2003 Silverado Misfire
timmdogg2
hey, I have a 2003 chevy silverado exd cab 5.3L. I recently changed my spark plugs and now i have misfires. I have been trouble shooting this problem for 3 days and it seems to be getting progressively worse each day. My neighbor has a code checker and it says that i have a random cylinder misfire (code p0300). We checked to see what cylinders were misfiring and in a 5-10 minute span i had over 1200 misfires in cylinder 1, about 500 in cylinder 8, and only 1 or 2 in every other cylinder. My ignition timing is going nuts ranging from 3 to 27 when the truck is just idiling. I have changed sparkplugs, and serpinteen belt prior to this happening. Since the problem has started, i have changed spark plug wires, cleaned my k&n air filter, and changed fuel pressure regulator. I have taken the spark plugs out made sure they were the correct ones and that i did not have any damage to them. Since i have a random mis fire i know that it eliminates any problems that have to do with individual cylinders or parts such as sparkplugs, wires and individual coil packs. It also back fires on acceleration occasionally, i do not have a clogged cat, my fuel pressue is a bit low at idle (50 at idle-62 when steppin on gas). I have also eliminated mass air flow sensor and fuel mixture is good at 14.6 I have used differents types of gas and did not effect it either way. it only seems to really mis under load(in gear) in low rpms, when i am above 2000 rpms u can not really tell anything is wrong, but like i said it is getting worse. somebody told me to change crackshaft sensor and im going to try that tommorrow. does anybody have any ideas? im getting frusterated!
I also have 2 new codes that popped up today, they dont sound like they relate to my problem above but u never know they are u1026 and u1041
The P0300 is very missunderstood to the general public. You would only get a P0301 if it was a flat dead miss and sometimes not even then. Of the thousands of P0300's I've ever diagnosed about 80% trace down to an issue at a single cylinder. Just because it's not a 301 does not make it random.
Now I'm not saying that it isn't something related to fuel that would affect all cylinders but I would investigate that cylinder #1 first. #8 is right after it in the firing order and your probably seeing a false miss on 8 because of the #1. You said you took out the plugs and checked them out did you swap cylinders by chance. This motor is simple to diagnose ignition failures on because everything is accessable and exactly the same. Without anymore equipment than you have you can swap the 1 and 3 parts out (I suggest plugs first and see if the miss moves to #3, if it does you know you found your problem. If it's not the plugs move on to wire then coil swapping.
This would make me lean the plug route if there was no miss prior to the plug and belt replace. The tinyest crack in an insulator can cause a hard to find miss. Also double check belt routing, proper belt and check the tensioner. All of those things have been known to cause false P0300's because the miss is seen as a variation in crank speed, a jumpy belt can make that minute change in crank speed that is picked up as a miss.
Oh and I almost forgot about this
These codes are for lack of communication between the ABS the transfer case shift module and the PCM. 99 times out of 100 if you remove the ground on the frame at the body mount under the front of the drivers door and clean the rail and terminals real good you will correct these codes. There is a bulliten giving some more detail, someone might post it for you but I can't do that anymore.
    DaleB
    DaleB
  • Who's Online   7 Members, 0 Anonymous, 1,301 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
