Engine Work - 454 Suburban
What started as an aftermarket post has turned into more of an engine post.  I bought a Performer intake manifold and some DynoMax headers for my '76 big block Suburban.  Well, one thing led to another and now the heads are in the machine shop and I've been scraping gaskets, etc.  This has now become more of an Engine topic than Aftermarket topic, so I'm posting this in case anyone hasn't been surfing in Aftermarket.
http://www.gm-trucks.com/cgi-bin/ikonboard...18&topic=20
Thanks,
Jeff
OK, the heads are back on, the engine and accesories are assembled, and I drove her around the block tonight...poor neighbors...wide open headers on a big-block is SO LOUD!!  Anyway, tomorrow I'm off for a new 2-1/2" exhaust system, and I hope to get the pictures on the web site soon.  I'll post here when I do.
Jeff
Well, all the work is done, and the Sub is like a new truck!  I have taken the digital pics, but haven't made the web page yet.  I'll post something when I do...hopefully somebody will be interested.
Jeff
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
