Replace Front End Parts...
Guest Riggs
Alright with 128,000 miles my front end is pretty "loose"
i can turn my steering wheel about 1/20 of a full turn (a good jiggle side to side about 2-3 inches)so that means what? pitman arm?
i am also thinking about cranking my t-bars 1/2" more so i am going to replace the front shocks too right away... i did the back ones right away since the bushings fell out of the old ones..
it just sucks cause since its so loose going down the highway the truck moves on its own and wont stay in a straight line.. looks like im drunk or something...
and when i replace the pitman arm should i get an alignment right away? i need one of those after the t-bar crank... will they be able to adjust with a t-bar crank? they couldnt on my old truck.. but putting the ball joints on the bottom of the control arm fixed that.. will i have to do that on this truck?
and is a pitman arm something I can replace? or should i leave somebody else do it?
They will be able to adjust for the torsion crank as long as you don't go much over an inch and a half over stock height. The amount of crank on your old truck was absolutely INSANE, that's why you had alignment issues.
And the looseness could be anywhere in the front end. Check the pitman arm, idler arm, inner and outer tie rods, etc. for play. I'd get the alignment right away just to be safe, don't want to wear out the tires prematurely.
i will replace parts as i get money prolly... and when im all done ill get an alignment...
1. Shocks
2. Pitman
3. Tie Rod Ends
3. Idler ( i heard these are stronger than the 88-95 )
with the add-a - leafs and a torsion key lift i would be nice to have it drive striaght down the road...
because after that stuffs done im buying a 3" body lift and 33" tires :D it will look like my old truck but an extended cab :D
NO! Put the wrenches down and step away from the vehicle!!!
Dude, your truck is perfect right now, don't go and Riggs it all up like the last one. :lol: Seriously, it looks great, maybe some new wheels but NO LIFTING!
yea maybe idk....
i guess i could just do the 1.5" ADD - A - Leaf and then crank thr front up about another 1/2" inch... (front sits 1/4" higher right now)
that should give it a pretty good stance.. i do really want to get rims too though..
since my rims are only 7" wide putting a stock offset 8" wide rim makes my tiers look wider too so that would be kinda nice...
I agree with Daddy, don't do the BL on your truck. The GMT400s just show WAY too much frame when they have a BL. I'd hold off on the AAL and torsion crank too, new wheels might give you the stance you're looking for. The further you crank, the rougher the truck will ride, and I know you hated that about your old truck. The torsion bars are just meant to be a small adjustment, not a cheap lift.
well i already bought the add - a - leaf...
plus i really could use the extra load capacity (would really come in handy for hauling the 4 wheeler) and the little clearance it gives...
and the front is far from fully cranked.. so i was just going to give it a "little" more so it wouldnt have a outrageous rake...
Its a Fabtech Soft Ride Add - A - Leaf
1.5" Of Lift.... hoping to be a little less....
so yea... that shouldnt look too bad its only an extra inch and a half.. there a few people i know that left there stock wheels on with a 3 " body lift (one kid here put a 4.5" body lift on (4 hockey pucks and left his stock wheels on) and this will be like half that and show no frame so it should be alright..
im guessing the 1.5" of lift is with ideal conditions with no leaf spring sag...
my friends 98 z71 sits 3/4" lower than mine so my leafs are pretty good compared to his :D
Just because there's a lot of bolt showing, doesn't necessarily mean you have more room to crank, but I have no idea what your front end geometry looks like.
Do you think you could take and post some pictures of your CV angles?
Please never ride in hockey-puck kid's truck. That is one of the most unsafe things you can do to a truck. Hockey pucks aren't meant to hold up to that kind of stress/pressure, nor are they meant to withstand the elements. If they chunk apart in a hockey game, I'd hate to see what they do as body mounts.
but i havent cranked it that far... and i dont plan on going that much more... the truck rides pretty good..
How Are These?
Haha damn dude, that was quick, I was expecting pictures tomorrow or something. :lol:
And those look good. You should be able to crank about another quarter to a half inch (no more than that though) without any trouble. Go for it, just don't go crazy like you did with your old truck. :D
Ok, time to watch women's beach volleyball. Oh guess what, it's raining there, and they're wearing white. :D
parents bought me a new camera 2 days ago so i like using it :D
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
