Electrical Problem, Indicator, Brake
I have an electrical problem with my 2001 Silverado 4wd ext cab.
Indicators seem to be working correctly, however when I press the brake the indictors start flashing much faster.
I replaced all the bulbs (all six in back and two each side in the front).
Ocasionaly when I press the brake the indicators just stop flashing.
Any idea where to look for the problem?
Thanks...Paul
Additional symptom.
I notice when I press the brake both indicator lights on the dash glow weakly.
Must be a short somewhere but no fuses are blown and both the indicatoes and brake lights still work.
...Paul
Not too many suggestions, but it could also be a grounding problem with the brake lights.
Do the brake lights try to come on when the indicators are used?
I'd suspect the turn signal switch.
+1
I'm not a tech but the emerg. flashers, turn and brake lights do combine in the multi-function (turn signal) switch for the logic switching/display decisions that are determined depending on the priority of the indication request: Brake trumps flasher, flasher trumps turn, turn trumps brake. This is where the highest likelyhood of a short between 2 of these circuits could occur IMO. You may find that your front signals are also illiminating weakly. Couple of hundred bucks for that switch. Did one on my '95 a few years ago.
    HWN808
    HWN808
  • Who's Online   1 Member, 0 Anonymous, 509 Guests (See full list)
