Replace Factory Head
New 08 2500 HD that I purchased without factory gps. Thinking about adding new head up front to add ability of video/ipod/zune and dvd. My decision is gps or no gps. I have both Delorme and Streets and Trips and severals laptops and can use that if I need gps. Wondering why no one makes a unit that makes use of a PC based product. I really want to be able to
make use of the avi videos I have so that is the most important. Any suggestions of the best product out there?
Thanks in advance
hey might want to have a look at this deck. I'm thinking about it for my self
http://www.bestbuy.com/site/olspage.jsp?sk...d=1209774346683
it has everything gps, built in blue tooth, ipod hookup, and dvd. Only thing is i'v been reading some reviews on it and its been mixed. Sounds like there is a few firmware bugs to work out still.
Thanks, I will take a look at. I have been considering the Kenwood 8120 or the Pioneer Z3.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 230 Guests (See full list)
