An Example Of Nature's Bad Timing
DofD
When it comes to wasps and humans there really isn't any good time, but this was really bad timing on their part.
Okay the situation, it's a long weekend, the weather is nice, and I have a bunch of yard work and maintenance stuff to do around the yard and house. So for this morning it was sweeping out the roof valleys of accumulated crud. Up on the roof I go with broom in hand. Now my roof also has a rather significant pitch to it and walking around on it is rather interesting. So there I am minding my own business sweeping away and trying to be careful about my footing. When all of a sudden this group of wasps decide to check out what I'm doing. Now at this time of year the wasps aren't too bright around here. I try waving them off, but they're rather insistant on getting up close and personal. More stern shooing only only results all of us getting annoyed. I haven't got many options standing at the peak of the house, the concrete patio below is a very unappealing option, the wasps are being stubborn about getting up close and personal (where no wasp should ever go), another unappealing option. So I continue shooing them, which keeps them at a distance but makes me a mostly stationary target. Now I don't think wasps are capable of tactical planning but that is what it seemed like. A couple of the wasps took on the task of buzzing my head. This then distracted my from the third wasp which took the opportunity to sneak up from below, land on my knee, sink his stinger in, and take off again without getting splatted. Reveling in their victory all the wasps decided they'd had enough fun and took off. Fortunately I'm not allergic to them. But those wasps can thank their lucky stars for if I had been on the ground, they'd be winging it off to someplace other then their nest.
I couldn't begin to count how many times I've been stung while working on a house. My most recent one was from a yellow jacket, or 2 or 3. The bastards attacked my head, and the one that really hurt was the sting I took on the eye lid.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
