* Another Chevy Added To The Stable..
dietz4ibanez
I just picked this car up today... Its a 93 Chevy Corisica LT with the v6 3.1... Its got a bad tranny supposedly so I will see what I can do with it... I would like to run it un a derby or I may pull the motor and sell it... Engine runs great! I think it has about 40k miles on it.. 135k total on the car...
Guess how much I paid for it...??
multiply that by $180... I got a couple e-mails about the motor and I think I might have it sold for $400
$135 ? HTF did you come up with a price like that?
:) math time, I can't wait
Well it was suppose to be like 150 but I had to get a new key for it that cost me $15 that I paid.. So I paid the guy $135... I technically paid $150... So its 50/50 on the math deal...
Well, if you can find a relatively cheap replacement tranny, you just might have a cheap ride on the local front or turn around and sell for a nice profit. dunno about the derby part, that car won't take very much punishment.
    Gkistler
    Gkistler
  • Who's Online   5 Members, 0 Anonymous, 806 Guests (See full list)
