Lly / Lbz / Lb7
Well its not an LB7,those were used from '01 to mid-'04.
The LLY was used from mid-'04 to mid-'06,And the LBZ was used mid-'06 to the end of the GMT800 truck series production ('07)
Look at the eighth digit of your VIN....If its a "2" you have the "LLY" Duramax,If its a "D" you have the "LBZ"
Oh,You can also look inside your glovebox on the "SPID" label,It will list the RPO engine code there.
Thanks alot buddy. The number is a 2 so mine would be the LLY. Do you know if the LBZ is the one that come factory with the 360 HP & if not which one? Thanks again
