Need Help Bose System
BOOSTD1
2003 SILVERADO SS WITH THE 6 DISC BOSE SYSTEM LITTLE TONO VOLUME COMMING FROM SPEAKERS CHECK ALL FUSES AND ARE ALL GOOD REPLACED HEAD UNIT AND STILL THE SAME PULLED THE CENTER CONSOLE AND I HAVE POWER AD GROUND AT THE AMP DO I HAVE A BAD AMP OR SOME THING ESLE WRONG? THE MAX SPEED CONTROL DONT WORK ON UNIT ALSO ANYBODY WITH AN IDEA THANKS
Welcome to the site. I hate to bust your chops but you may not be getting answers because of the use of capital letters and no punctuation. I know it seems harsh, it's the internet and all but it's hard to read your post. I keep reading it to myself and get out of breath reading it. There is like 4 thoughts in one huge sentence. It's hard to figure out what you are asking.
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 481 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
