04 Envoy Mods
gnwatson
I have a 2004 envoy, 4.2L and i'm looking for some decent performance mods. I put a new intake on with some meager results, but i'm looking for the killer shit if there is any for this engine.
Watch your language, there are children present. :lol: As for "killer stuff" I dont really know of any. A few companies make the typical bolt ons for the 4.2L and a few even have programmers/modules, but as far as Turbos/Supers/N20 I think your on your own to make a custom kit.
Lots of people have built them up, but like I said, most hardware is custom. Dont worry about your transmission. Its the same one GM uses behinds a variety of V8's.
    rayredbone
    rayredbone
  • Who's Online   4 Members, 0 Anonymous, 388 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
