5.0 V-8 Mpg
Pretty sure that the 5.0 was made by Ford. I would guess that you mean either 5.3 or 5.7, right?
I'd try searching, I'm sure someone's brought it up before.
305 = 5 liters.
Weren't the two engine sizes 5.7 and 5.0 on the GMT400s?
And when the LS family of engines came in the truck engines (in half tons) went to 5.3 and 4.8?
305 = 5 liters.
Damn, I figured that since the 301 was a 4.9L that the 305 would be too. My bad....
305 = 5 liters.
You are forgiven. :thumbs:
305 = 5 liters.
5L also = 302 ci
even though i dont have a 5.0 (305) i have the 5.7 and my last fill up i got 14.5..
i just got a vinyl cover this week though so it may go up a bit more. 18 is pretty good. i got 18.5 with a 4 wheeler in the back on a 50 mile trip one time though.
305 = 5 liters.
5L also = 302 ci
Cubic inches of an engine are 61 inches per liter give or take 6 inches depending on rounding.
305/61=5.0
350/61=5.73 rounded down to 5.7
302/61=4.95 rounded up to 5.0
346/61=5.67 rounded up to 5.7
So, by that logic, I know have a 6.3l engine.
Yes, by the math you have a 6.3L stroker engine in your truck.
383/61=6.27 Rounded up to 6.3L
:shakehead:
:shakehead:
It's amazing how many freshmen/sophomores in college don't frickin know how to round. Every single lab partner I've worked with this year except one has had no grasp of how to round.
One was pretty hot though, so I'll forgive her. :banghead:
:shakehead:
Hahaha. I know what you mean. In my physics class of 24 students 2 (one was me) knew how to round. It was pathetic.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
