Tint Question
I have searched for tint and did not see a thread like this, so forgive me if I missed it.
I want to tint my truck up with F1 Pinnacle 35% just like my car - love the matte look of this tint. The truck came with the rear seat and back glass tinted already. I'm somewhat OCD with my vehicles and want the tints to match all the way around. Is there a way to remove the factory tint (I'm thinking not) or a tint that would match the color and light transmission out there that I don't know of?
I'm seriously considering replacing the two rear windows so my tints will match at least on the sides. The tints will be legal - barely, of course. 32% for my state.
Image of what I want on it from my car:
the deep tinted glass that comes factory is between 15 and 20%
I went with 20% on my front windows and it matched up pretty well. I think the factory tint is closer to 15% though
I checked it using using my tint meter and it comes in at 19%.
Mine came in at 18%....do you plan on doing the work yourself or having a shop remove the factory tint?
There is no way to remove the factory "tint". It is actually shading. Tint always involves film. The only way to rid of the shading would be buying new glass. Usually, a 20% film will match the rear, but since you say you're OCD about your vehicles, it would be best to find a reputable tint shop with a wide variety of films(i.e., dyed, metallized, ceramic) who will help you make the decision of which type and percentage of tint to go with. Hope this helps and Good Luck!
+1
20% tint will match the rear windows perfectly, that's what I would do. Too much of a hassle to buy the 2 rear windows without stock tint & tint them with 35% tint.
