Ac Pump Issue Affecting Engine?
Hello, and thank you for your time. I have a 2003 Trailblazer 4200 with the straight 6. The engine, (with 70k miles) idles at about 700rpm but when I turn the heater on the engine stalls, when the AC is cycling the engine rpm's fluctuate (hunts) and stalls. I have replaced the Fuel filter and air cleaner. I have a suspicion that the problem may be the AC pump. Where should I start looking?
Thanks again.
Rich
I think you may have a voltage issue. Accessories will not stall a healthy running engine. Does the idle speed drop when you power up other electrical accessories? Do the headlights slow the idle?
Start by checking the main ground. My '91 ran like hell for months as I tracked down "problem" after "problem." Turns out the electrical system needs a good ground for everything to function properly. Who knew? :dunno:
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,157 Guests (See full list)
