Does Gm Make A Roof Marker Kit?
No try aftermarket, Gm has a liability issue if you were to drill into your roof, and mess up your truck
Pacer automotive lamps , makes the oe style kits that are also avallible in carbon smoke and amber. Comes with everything you need. Ive put together a kit for a guy and we stoped looking at like $270 with the harness and all.
Do you have a link? Is it a kit or does it only include the lights?
Yes, GM does make a roof marker lamp kit. I've always had them installed on my truck and they can be purchased from the dealer. When I ordered my 2008 1/2-ton the lamp marker kit was not an option. The dealer offered to have a private shop do it once the truck came in. I did not choose that route and I ordered them after purchasing the truck and a friend installed them for me.
The new model roof lights ran me about 270$ for everything from the dealer.
Part numbers for the `07 - `08 GM marker lights.
25826849 - right lamp
25826848 - left lamp
25826850 - center lamp
25823584 - harness
Well you can buy them from the dealer in individual pieces,however they are not available as an actual GM accessory "kit".
As sablowme said,GM does not want you adding items that were not installed at the factory,unless they are available as a GM accessory.
When you get a chance, and if it's not too much trouble for you, would you mind getting me the part numbers for the left lamp, center lamp, right lamp, and harness for a 2003 Silverado? The part numbers xGMCx are for GMT900s and I am not sure if those are the same ones used on the gGMT800s.
Sure,When I get to work tomorrow.
The GMT800 and GMT900 lights are different.
Thanks. I appreciate it.
OK,Heres some numbers for you.
The center light is 15219564
The outer lights are 15059752 (Both left and right are the same)
The wire harness is 15846970
thanks for the assist there, MS3DALE. Thats the reason i didnt give part numbers for that 08 cuz the
guy actually had a 03. Some people are looking for something differnt but most of the time there looking for a kit to add. Its just like fog lights, If gm dosent make a "kit to add" there proboley is a good reason why.
See Vortecz71, and this is just some info on how this works as Ms3dale gets back to you because im also in GM parts myself, just used to be a gm accessory rep...for the ADI's. Anyway GM would like to offer lots of these things like fog lights,roof racks,roof marker lamps, and performance parts but they want to check them out first just to make sure no one gets sued or it dosent work and fit under gm warranty. They put a quote out to many manufacures to see who can build it, how easy does it bolt on (cuz our customers need to do this in there garage), and how much does it cost. All of this goes into affect when a new product arrives.
For example GM had the cargo management system in test vehicles back in 2001, but didnt actually go into production till the gmt 900 trucks. This is how intense the test process is. The GM hard shell tonneau covers you see on the gmt900 trucks went through vigorous test before Penda-liner could relase it to GM, The GM one is the only one moulded in color and abs plastic at the same time for now. So this gives them first to market value.
I didn't realize how much work went into making GM accessories. Now I can see why it would take so long. I've always liked the looks of roof maker lamps. I prefer to use GM accessories on my truck as opposed to aftermarket products. If I were to go with the GM roof marker lamps, it looks like I would be paying $311.40 in parts. Does anybody have any idea how long it would take take for the dealer to do the install and a rough estimate of what I should expect the labor cost to be?
Also, are roof markers on all of the time like DRLs or do they only come on when it gets dark?
I usually see them hooked up to the parking lights.
Yeah,The harness will plug into the electrical center on the RH side of the dash (You have to open-up the door to access it) and they will come on only with the parking lights (And of course the headlights also when they are on)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
