Under-box "step"
Damn, those sides are high!
Looking for a step (foldaway preferred) to mount ahead of the dually "bulge" so I can climb up and pull latches on 5th wheel hitch and otherwise reach into front part of the bed.
Wear platform shoes!!! j/k!
Whatever happened to using the tires? I guess that's just the way I've always done it if I couldn't reach what I was after...but then, I'm REALLY cheap.
Just be careful leaning into the bed... I heard our sheet metal can dent pretty easily.
It seems the dually's are tougher. My bedsides are noticeably stiffer than my 03 2500HD was.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
