Yep, Another Mpg Poll
Mileage for 6.0 Gas HD
197 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Trying to get the best estimate of HD mileage in various situations....
For those folks that get exceptionally good mileage, please note what you have done to increase the mpg so the rest of us can opt for the higher numbers.
Those folks with exceptionally poor mpg, please give an indication as to why...
Thanks
yep, another 6.0 mpg poll reponse-HA!
Add'l info needed like gears/tires/etc because my CCLB with 285's, steel wheels, and 4.10s will get worse MPGs than just about any other 6.0 because of weight.
I guess that doesn't matter though as you looking for reasons for good mpgs-nevermind
Ok , I get about 12-13 with 285/75 on. It used to get about 15 with stockers. I just towed a couple of four wheelers on a 16' trailer and got 10 mpg. This is all mostly highway miles.
was getting an average of 20 mpg on hiway with stock 245/75R16 and 3.73 gears, no aftermarket tuning, hard tonneau cover, moved to 285/60R18 and mileage went down at least 1 point but still trying to find out exactly
I added an AFE stage II cold air intake and changed all my fluids over to amsoil, have no problem getting 15-16 mpg highway with 4.10,s and the 245/75's on steel wheels at 75-80 mph with hills.
I get 14-15 with averaging 41MPH per tank, but pure highway I can get 17-18MPG. With stock tires I used to average 16MPG but the 265's killed my mileage. I have a tune and magnaflow exhaust. I will note that our gas stations now use E10 exclusively and my MPG went down a gallon because of it.
In the city I average about 12mpg. Highway around 13-14. But while towing my travel trailer (35ft toyhauler) I get 8-9mpg! It sucks but you can't do the types of things I like to do driving a Prius!!!
My 08 hd NBS CCSB 4wd gets 11 no matter what i do. It has the 6spd with 373's, and i feel like it can't pull its own weight. It is constantly shifting either for hills or head winds. I have 285 coopers on it with a ready lift torsion key kit installed. Towing an 18 foot boat I'll get 8 or 9. On the highway i'm lucky to break 11.5 unloaded. I hate it, so i've been lookin for the old body style diesels.
I get 11-12 in the city and 14-16 on the highway. Mine also shifts more but that's the nature of the 6spd. The more gears the tranny has, the more it's gonna shift to keep it in the powerband it requires.
Driving like a granny I get about 14.7 with mine on the highway. 02 ECSB 4x4 4.10's 265's
About 12-13 around town and about 9 towing a 4000# 4Runner on a 3000# 24' trailer. Last weekend I smoked about 3/4 tank towing 130 miles trying to run 80 with hills. I need to chip this thing bad. But I drive a car most of the time and only use the truck for towing and hauling
Does anyone make a good programer that will get more than 1 mpg better than stock for these motors? Most of the ones i've research don't really do that much better for 400 bucks. If anyone knows i'd love to hear about it before i trade mine in.
I had a Diablo Predator on my 07 Classic...supposed to be the best of the hand held programmers....worthless in my opinion. Mpg did not change and the preformance increase was barely noticeable....shifted damn hard at 4500 rpm or above. It came with a 30 day return guarantee....I kept it about two weeks.
I am in the process of getting a custom tune and most folks that have them say they are good for 1-3 mpg....we'll see!
My Crew Cab Short Bed 4x4 05 2500HD 6.0L got a highest of 13.8mpg summer city, 12.9 in winter, 12.6 after Flowmaster mufflers.
Never had it on the highway, never towed.
I remember a steady 14 mpg out of my 2000 6.0. Now it gets 11ish. Has anyone had improvements by changing the O2 sensors on high mileage rigs? Mine has 240k and I wonder if my milage is suffering because the O2s are worn. My 98 suzuki car mileage improved from 32 to 37 with O2 sensor replacement.
If they're the original O2 sensors It sure wouldn't hurt, the degrade over time and there is a lot of leeway in the computer before they will set a code. Do the pre cat ones as they set the mixture.
I get a steady 14.5mpg mixed driving.
