1997 Chev 5.0 No Start
bobsully 1997
Just replaced the lower in take manfold .roter is at #1 plug wire.# 1 plug at t.d.c. still no spark .replaced coil still no spark. i have read every thing i why i am getting no spark, also hooked up a obd 11 auto scanner , no codes found .I just found out what I did wrong . When I pushed the crank sensor plug in I bent one of the prongs. thanks GRAMPADIRT for your help
I had the same problem on my '95,after spending a ton of money I saw on a thread here to check all the wiring in the engine compartment,it turned out to be a wire from the oil pressure sensor which had melted against the exhaust manifold under the power steering pump,pulled the wire loose and VROOM!! started right up..so check that.It seems there is a built in safety feature where unless the ECM sees oil pressure the engine won't run.Maybe you cut or pinched a wire somewhere.
good luck,Gary
good luck,Gary
    250.3k
    Dad X MTB
    Dad X MTB
  • Who's Online   1 Member, 0 Anonymous, 326 Guests (See full list)
