C6500 Cat Diesel No Electric Power
So I unfortunately own a 1998 GMC c6500 with a cat diesel. I bought it to move across country thinking Id sell it when I got there. Boy was I wrong.. no one wants a nice 115k miles truck.. anyhow.. its mainly parked in my driveway for the last year.. I use it once in awhile and move it once in awhile to get something in or out of my garage. The other day I started it up and drove down the road to park it and it died. No power at all when I went to start it.. no lights, nothing... I pulled the main fuse panel off.. messed with the fuses and found none blown.. went back in and it didnt start. Just when I was about to pull it back and park it with my DODGE truck.. ;) I tried it again and wham.. power.. it was cool out around 40.. so the glow plug light came on... I let it go off and started and let it idle for about 20 minutes. Later that day I started it back up and put it back in the drive.
2 days later.. its 35F out and I go to move it.. nothing.. no power at all.. no lights no fan no nothing.. I put a portable battery pack on it in case the batteries went dead.. nothing.. nothing on the volt meter either.. I heard a "click" when I first turn the key to ON.. NOT to start but to ON.. and then noticed no lights.. no glo plug lite etc..
Its fricken cold out now and getting dark.. I plugged the block heater in figuring this might be temperature related and I'll try again in the morning.. but does anyone have any clue what this might be? I really need to move this thing.. I have a freshly sandblasted trailer waiting to be put in my garage! I hope it does not rain or anything or I am screwed..
My first thought is to pull every single relay and clean them and use some grease on the connectors tomorrow.. But I dont even know where they all are.. Ive found 2 in the engine compartment thus far.. are there any under the dash?
Is this a common problem? Its gotta be a simple fix... I would think.. any help would be appreciated in preperation for tomorrow's fun.
thanks
Joe
Check electrical connections and make sure the batteries are fully charged. How old are the batteries? The may not be able to put out the CCAs.
I have a power pack on it and no juice.. nothing.. so its not the batteries.. something is not allowing current to flow at all.. I'll check connections of course but Im hoping someone has seen this.. maybe this truck is too big for this forum though... I was just looking and "heavy duty" apparently means one ton pickups.. I may have posted in the wrong place.. if anyone knows of a real heavy duty forum let me know.. I should say medium duty actually is what they call this group of truck.. y'all are light duty if you are 1 ton or less.. anyway.. this blows.
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
