Amp Question
franciss8
If I am wanting to install the TNR Navigation option in My 2007 Classic 2500HD Silverado, do I need to get a Lux AMP? I do not have a BOSE system in the truck, so if so, does anyone know the part # of the lux AMP/non BOSE? Or could I just find a 1580000 Navigation unit and skip the AMP? Does anyone know the Delphi Part number that is equivilant to that unit? Sorry for all the questions, but I would rather spend my money once that spend it more and have to explain to the wife, lol.
Thanks
Francis
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
