Transmission Cooler
isis
I have 2001 gmc sierra c3 with a 6.0 liter.I noticed the overflow reservior had transmission fluid in it.I don't have any coolant in the transmission but transmission fluid in the coolant.I pretty sure it is transmisson fluid because it is redish color. Is this a common problem in this vehicle? I will send a picture of the coolant color shorty?Any suggestion i would appreicate.
If what you see in the recovery tank is red,fear not.GM uses red colored coolant in their vehicles.I've heard good and bad things about this stuff....look into it more.But keep an eye on the tranny dipstick just to be sure.I can't recall ever hearing of the cooling tube leaking inside of the radiator.
Did they use red in '01? My '00 is green. If it's tranny fluid in the tank it won't mix but will float on top.
If it was green then someone else replaced it. GM started using the orangeish/redish Dex-Cool Coolant in the 400 series trucks (at least the 96-98s).
There is some easy advice in bold. ^
Yep, my 2000 had the red Dexcool in it.
Sorry guys, mine is red too. Quite often I don't know what I'm talking about. :crackup:
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,142 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
