Leaking Np246 Transfer Case
drag230
I have a 2002 Yukon XL 2500 with an 8.1 liter engine. It has 75,000 miles on it. It has a New Process 246 transfer case assembly number 1577 2806. I found a pin hole in the rear of the transfer case on the right side where the rear drive shaft exits. It is Not on the tail shaft of the transfer case. It is about where the tail shafts starts. I repaired it with JB Weld (had to, I was 1,500 miles from home) and thought I should check into it. Keep in mind this suddenly happened and started over night. I have heard this is a common problem with these transfer cases. I have heard that something is failing inside that caused the pin hole. Is this True? This was a GM certified used vehicle. Does GM have any recalls on this? Do I have a case to get the dealer to repair at a reduced cost or even free? LOL!!! I consider myself a better than average shade tree mechanic. I build all my drag motors and restore old Pontiacs. Is this something I should just repair myself? If so, do you know a good source for rebuild kits. Thanks for the help in advance. John
  • 4 weeks later...
To get more information about this problem, I'd recommend visiting thedieselplace.com .
There is a spring clip that seats inside of nook on the transfercase that helps retain the pump, which rotates at driveshaft speeds all the time, even in 2WD. When that clip unseats, the "pump rub" issue eventually manifests itself, as the magnesium housing gets rubbed in a concentrated area and thus worn thin/beaten enough until it rubs through.
The issue is reported more often with 261 and 263 cases, that are mated with the Duramax/Allison, more so than with the 246 cases. That's why I recommend the the gm diesel truck user website mentioned above.
New Process designed a new replacement pump retainer clip that is available through GM parts, or, alternatively, you can contact Dan Merchant at Merchantautomotive.com, who designed a more robust cnc machined pump retainer that has been a popular fix amongst the GM diesel truck owners.
I dread this problem surfacing in my similar out of warranty 2500 YXL, so that is why I try to keep up to date on this subject. It is a cost cutting, under engineered design defect, according to an inside source at NP/NV, the supplier of the TC, who reportedly tried to warn GM that problems would surface, but was forced to go with the lower cost option until the problem became widespread. There is no recall because it is not a safety issue. It's just an issue that makes one think twice before buying another GM vehicle.
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
