Newb!
Bmart
hey guys, just came across this forum while trying to solve a really stupid problem im having with my centre console... my name is brian, i own a 2001 sierra sl 2wd reg cab short box with the 4.3l.. very clean truck, spotless if i say so myself... ill upload a pic later on, have a good one!
am i blind?? i can't seem to find where to add a picture of my truck in my signature under my posts....
Click on the My Controls link near the top of the page, below the banner. Then on the controls page click on Edit Signature in the Personal Profile section. In there you can create a signature for your posts and you can add a picture.
Click on My Controls and then click on Edit Signature...
Welcome to the site, Brian!
Welcome, Did you fiqure out how to add your Photo??
well i made it that far, but all i find is an insert image button that asks me for a url.. im trying to upload a pic from my computer..
and thanks for the warm welcome everyone.
I suggest using photobucket. :jester:
Ahh! You'll need to upload an image to Photobucket or such, then use the URL for the image from there for the picture in the signature. Unfortunately you can't upload a picture from your computer to the server to use as a signature pic.
I see you got the sig thing figured out, but it's way too big. The size limit is 200 pixels tall by 700 wide. :jester:
Photobucket has a resizing feature that's pretty easy to use.
EDIT: By the way, welcome to the site, didn't realize I hadn't said that yet. :cheers:
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
