Impala ?
hey all
i tried asking this question in some impala forums but got no answer so i thought id ask here.
its a 06 impala 3.5l and when it is idling it doesnt blow heat. but once you start driving it blows heat again.
i have check the fluid level it is full.
could it be the thermostat? this car only has 48000kms on it.
any help would be great i have a very cold wife right now that is doin alot of complaining
I know you said you checked the fluid but do it again.My wife has a 06 ltz impala 3.9 and it did the same thing and the fluid was a little bit low got it topped off good and that fixed it. I would of never thought that was it.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
