Remote System Stopped Working.
I drove down to O'Reilly Auto Parts earlier to grab a Wix filter for the oil change tomorrow and when I got home and tried to lock the doors with the remote, nothing happened. No lock, no unlock, no panic, no anything. I assumed the battery died in the remote so I grabbed the other remote but unfortunately, I got same result. I'm going to disconnect the battery tomorrow and see if that helps but it sounds like it'll be going back to the dealer, again.
RF doesn't work without an atmosphere. :happysad:
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
