Need Xm Install Help
So I posted late last week about a Heated Seat Install, BOSE Radio Install, and an XM Radio Install in a 2007 GMC Sierra Classic, which was an SLE-1 and I basically made it an SLT with the puchase of All-New or Slightly Used GM Parts....everything was practically plug and play and all I need left was the programming....
Anyway long story short I took the truck to the Local GMC Dealership on Friday where I know alot of the Techs and I have had these kind of options programmed before, after I had added them to the trucks which didn't come with them....basically the way they were doing this was calling GM TAC and getting the Vehicle Configuration Index rewritten to accept the new RPO Codes and begin to let the features work....
This Friday was apparently a different story.....so basically what I have done was added the features, gave them the RPO Codes, they called TAC, and then the Guy at TAC proceded to explain that something like this would be completely impossible and that if the truck wasn't built with it, we can't actually add it.....and this is all the further we could get with this guy.....(again we have done this before)
After this the Tech and I go thru the programming screen on the Tech 2 and we are able to get the BOSE Radio and the BOSE AMP Activated by ourselves by using the RPO UB0 and UQ7.....basically that is one thing off the list.
The problem I am having now is that while the Tech 2 can see the Memory Seat Module, and the XM Radio Receiver, it is not able to unlock them without this Reconfigured VCI....basically these two parts were out of a different vehicle and are VIN Locked and he cannot figure out how to get them to operate properly......the worst case is...I know that the truck can see that they are there, I just can't use them...for example I get a Memory Seat Beep when using the Buttons, and I get an "XM Lock" message on the screen when I go to the XM Feature on the Radio....
I know this maybe a shot in the dark, but maybe someone on here has some access to some information that can help me make this truck finally work the way we had intended it to....again everything is factory, plug, program, and play....its not a bunch of chopped up wiring or anything like that....
Anyone out there have any suggestions?
Thanks
