Which Header Should I Get?
10 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Welp, i've got an 03 GMC Sierra Single Cab Short Box
5.3L Vortec V8 w/ 40 Series Flowmasters dumped out behind the cab and im looking for something that gives a good level TORQ and HP gain and with a good clean crisp rumble. But im kind of leaning towards Borla for the most part. Whats your input?
Personally, I wouldn't do shorties. I'd go long tubes or go home. If you're worried about the loss of power on the bottom end, get a bigger torque converter...Unless you tow...Then you're hosed. :bs:
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
