Horn Switch
dannyboy20
Ok I have a 98 GMC Sierra and the horn works occasionally. I have determined that its the switch in the steering wheel. However I canot get access to it. I have tried a couple of different times to remove the airbag bu I cant get at it. Is there some kind of a diagram for this. I have the repair book but it only shows the older style trucks. Im getting desperate becuase my sticker is up in January. Thanks.
Horn Switch Replacement - On Vehicle
Removal Procedure
Caution: Before servicing any electrical component, the ignition and start switch must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
Remove the battery negative cable.
Disable the SIR system. Refer to Disabling the SIR System .
Turn OFF the ignition switch in order to unlock the steering wheel.
Turn the steering wheel 90 degrees from the straight-ahead position in order to gain access to the access holes behind the steering wheel.
Insert a screwdriver into each access hole and push the leaf spring in order to release the pin that retains the steering wheel inflator module.
Turn the steering wheel 180 degrees in order to gain access to the remaining access holes.
Tilt the top of the steering wheel inflator module rearward.
Remove the SIR lead wire from the clip on the steering wheel inflator module.
Remove the SIR lead wire from the clip on the steering wheel steering wheel.
Remove the connector position assurance (CPA) retainer and the electrical connector.
Caution: When you are carrying an undeployed inflator module:
• Do not carry the inflator module by the wires or connector on the inflator module
• Make sure the bag opening points away from you
When you are storing an undeployed inflator module, make sure the bag opening points away from the surface on which the inflator module rests. When you are storing a steering column, do not rest the column with the bag opening facing down and the column vertical. Provide free space for the air bag to expand in case of an accidental deployment. Otherwise, personal injury may result.
Remove the steering wheel inflator module from the vehicle.
Disable the supplemental inflatable restraint (SIR) system. Refer to Disabling the SIR System in SIR.
Remove the inflator module. Refer to Inflatable Restraint Steering Wheel Module Replacement in SIR.
Remove the horn contact from the steering column.
Remove the four TORX® head screws from the two contact plates.
Remove the two contact plates from the steering column.
Installation Procedure
Install the two contact plates to the steering column.
Install the four TORX® head screws in order to secure the two contact plates to the steering column.
Install the horn contact to the steering column.
Install the inflator module to the steering wheel. Refer to Inflatable Restraint Steering Wheel Module Replacement in SIR.
Enable the SIR system. Refer to Enabling the SIR System in SIR.
