bfg 275/65/16
i once not long ago saw a picture of a truck with 275/65/16 tires. this truck was a 2wd stock height.I can't remember where I saw it.I was thinking of this size and any opinions would be appreciated.
                                 mike
  • 3 weeks later...
Hate to think that anyone would be ignored...
275/65/16 is an odd tire size???  When I search for it in Dallas on DiscountTire.com it tells me that this is an uncommon tire and that it doesn't exist in Dallas at any of their stores (though it can be ordered as a P275/65R-16 111S RWL from BFG).  I haven't see any pictures of trucks with this tire.  There are several with aftermarket tires (like 285/75/16).  Just check the mod's rides and you'll see examples.
So...  I responded, but I wasn't really any help.  Sorry  :)
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
