Lower Ball Joint Replacement
Has anyone had to replace lower ball joints due to the boots bursting? I recently bought a '96 K1500 and went through and greased all the fittings. They seemed to take the grease fine until I got to the lower ball joints. It kept taking grease until the boot burst. After further investigation, it looked like the aftermarket undercoating put on by the previous owner, combined with old grease and dirt had prevented the boot from opening up and releasing the excess grease.
For those who are looking to replace the lower ball joints on this model, you're absolutely going to need a ball joint press that you can rent for free at auto parts stores. There's no other way to get the new ball joints in. I found that it took all the force I could muster to press the ball joints in. I was afraid I was going to break the tool or my breaker bar or both. It's one heck of an interference fit - about .008".
There are actually two different ball joints for this application. There's a ball joint that's used for forged lower control arms (MOOG part number MOK6509). It's about .090" larger diameter than the ball joint used for the stamped and welded control arm (MOOG part number MOK6407). Make sure that you get the right size for the control arm on your vehicle. When replacing the ball joints be sure to point the grease zerks in the direction of the cut-out relief in the lower control arm.Lower ball Joint
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 280 Guests (See full list)
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
