Random Stalling
The other day I had backed up a ramp to pick something up. When I went to start, it would turn over for a while, start and stall. I finally managed to step on the gas while it was running so it wouldn't stall. I made it back to my shop by left foot braking while keeping revs up with my foot on the gas. I stopped it, waited for a minute and restarted everything was fine and has been okay for the last couple of days. While trying to get it to run a "service 4whd" light came on briefly. It went out and no other CEL have come on. Any suggestions??
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
