Back Fire, Non-ign. 'miss'
KENNHON
I have had NO problems with this beauty [Crew cab duallie] since new in '96... it now has 130,000 miles.... vacuum is showing 17 inches-is this low?but, it's steady. Fuel press. is 40 psi-my book says it should be 60 psi.... the pump was replaced 10,000 miles ago[ a premium Carter]. the EGR valve has 5 volts supply, and the valve has no open circuits. EGR plunger works fine off car; spring is fine.
The problem is that at 50 mph, there is a 'backfire',or 'hick-up', feels like a NON-ign. 'miss'. When any throttle is given, the 'hick-up' goes away. It idles fine, gas mileage is ok on highway 13-14 mpg at 70. plugs are new. wires are new. no wobble in distributor shaft.
Any help would surely be appreciated!!!!!!!!!!!!!
Well. i 'dove' under truck... cat's are fine[heh,heh]... ckd fuel volume.... 1 1/2 pints in 30 sec's[that is above av.].... both before, and after[+/-]. BUT i found what was the matter when i started taking off parts starting with my K&N filter.... when i got to Throttle Body, i immediately saw what the problem was: the throttle blade has a SMALL hole in it[remember doing that? drilling a hole[or holes] in the throttle blade of Holley Carbs when you had a big cam?.
This hole was completely plugged up! cleaned that out, then went and got the 3M cleaner kit from Napa.... the idle is fine, no variation, no codes!!!
Remember, i have 130,000 miles on this!
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 623 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
