Unlock/lock Stopped Working
Ok so....like normal when you go to put your truck in park and its automatically unlocks the doors for you....i go to open my door and get out my truck and my girlfriend says she cant get out...i thought she was full of it the first three times it happened...Well she wasnt....when i push my lock and unlock it looks like it wants to but it doesnt. Anyone else had a similar problem or has any idea what it could be before i take it into the dealer?? This kinda sucks i dont even have 10,000 miles on my truck and ive already had a busted speaker (not from playing it loud) and my locks messing up. Not to mention my truck tends to blow alot of carbon out...i can never keep my tips clean! :lol:
If you press the lock/unlock button on the passenger door, does the lock work then ?
Sounds like the lock mechanism in the door is buggered.
10k's is early...way early. but you never know.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
