Nbs Radio Removal
I took my radio out and it was super easy. you can just pull the trim around the dash and it will release the trim around it. It just clips in. Then there is just screws that hold the actual radio in. Pretty simple
Hope that is clear as mud???
Too all,
Does anyone know how to remove or have a instructions on removal of OEM radio from the dash with out damage?
r/,
Too all,
r/,
pull out around radio bezel edges, theirs i believe 6-9 clips holding it on... i start with the upper right vent area and work my way around. after thats its just a few 7mm screws holding it in...
Yeah like these guys said, just pry the bezel out to release the clips, release the 7mm bolts, and you're good to go. You do have to remove the bottom switch panel and HVAC controls first though. Just be careful, if you work too quickly you can mar either the bezel or the dash.
exactly.. only thing I would add is that it's a bit easier atleast to install if you remove the upper cover over the instrument bezel. 2 screws from the bottom side then pull it towards you.
Brian
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
