Not Exactly Another Tire Tread
Quick question. Do the Cooper Zeon LTzs come in sizes for a 18 inch rim? I have stock rims and have narrowed it down to either Terra Grapplers or Zeons after reading all the treads up here. However, on discounttire there are only 20 inch coopers.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
