White Door Covers
hey guys i have an 08 silverado white crewcab. i have been looking through old posts and searching on where to find the white door handles for my truck. all i can find is chrome. the dealer was not much help. said they couldnt get them even though the ltz have them. several good posts on here on painting them but dont think i want to go that route yet. anybody care to help me out on where you may have found them. thanks. also have checked ebay and havent seen white just chrome. hate to ask again becuase i have seen it brought up in past posts doing my searching just cant seem to find them. a few links no longer work on some places to order where i found them in old posts. thanks again.
